Changes between Version 2 and Version 3 of TracBackup
- 04/22/15 15:11:43 (10 years ago)
TracBackup
v2 v3 1 = Trac Backup = 1 = Trac Backup 2 2 3 [[TracGuideToc]] 3 4 4 Since Trac uses a database backend, some extra care is required to safely create a backup of a [wiki:TracEnvironment project environment]. Luckily, [wiki:TracAdmin trac-admin] has a command to make backups easier: `hotcopy`.5 Backups are simply a copied snapshot of the entire [wiki:TracEnvironment project environment] directory, including the database. Backups can be created using the `hotcopy` command in [wiki:TracAdmin trac-admin]. 5 6 6 ''Note: Trac uses the `hotcopy` nomenclature to match that of [http://subversion.tigris.org/ Subversion], to make it easier to remember when managing both Trac and Subversion servers.'' 7 '''Note''': Trac uses the `hotcopy` nomenclature to match that of [http://subversion.tigris.org/ Subversion], to make it easier to remember when managing both Trac and Subversion servers. 7 8 8 == Creating a Backup ==9 == Creating a Backup 9 10 10 To create a backup of a live TracEnvironment, simply run: 11 {{{ 12 13 $ trac-admin /path/to/projenv hotcopy /path/to/backupdir 14 11 To create a backup of a live TracEnvironment simply run: 12 {{{#!sh 13 $ trac-admin /path/to/projenv hotcopy /path/to/backupdir 15 14 }}} 16 15 17 [wiki:TracAdmin trac-admin] will lock the database while copying. ''16 [wiki:TracAdmin trac-admin] will lock the database while copying. 18 17 19 18 The resulting backup directory is safe to handle using standard file-based backup tools like `tar` or `dump`/`restore`. 20 19 21 Please , note, that hotcopy command does not overwrite target directory and when such exists, hotcopy ends witherror: `Command failed: [Errno 17] File exists:` This is discussed in [trac:ticket:3198 #3198].20 Please note, the `hotcopy` command will not overwrite a target directory and when such exists, the operation ends with an error: `Command failed: [Errno 17] File exists:` This is discussed in [trac:ticket:3198 #3198]. 22 21 23 === Restoring a Backup ===22 === Restoring a Backup 24 23 25 Backups are simply a copied snapshot of the entire [wiki:TracEnvironment project environment] directory, including the SQLite database. 24 To restore an environment from a backup, stop the process running Trac, ie the Web server or [wiki:TracStandalone tracd], restore the contents of your backup (path/to/backupdir) to your [wiki:TracEnvironment project environment] directory and restart the service. 26 25 27 To restore an environment from a backup, stop the process running Trac (i.e. the Web server or [wiki:TracStandalone tracd]), restore the contents of your backup (path/to/backupdir) to your [wiki:TracEnvironment project environment] directory and restart the service. 28 29 ''Note: Automatic backup of environments that don't use SQLite as database backend is not supported at this time. As a workaround, we recommend that you stop the server, copy the environment directory, and make a backup of the database using whatever mechanism is provided by the database system.'' 26 To restore a PostgreSQL database backup, use the command: 27 {{{#!sh 28 psql -U <user> -d <database> -f postgresql.dump 29 }}} 30 The `<database>` option is the same as the [TracEnvironment#DatabaseConnectionStrings database connection string] in the `[trac]` `database` option of //trac.ini//. 30 31 31 32 ----
