Changes between Version 3 and Version 4 of TracPermissions
05/08/22 15:10:12 (3 years ago)
  • TracPermissions
    v3 v4
    44Trac uses a simple, case sensitive, permission system to control what users can and can't access.
    6 Permission privileges are managed using the [TracAdmin trac-admin] tool or the ''General / Permissions'' panel in the ''Admin'' tab of the web interface.
    8 In addition to the default permission policy described in this page, it is possible to activate additional permission policies by enabling plugins and listing them in the `[trac] permission_policies` configuration entry in the TracIni. See TracFineGrainedPermissions for more details.
    10 Non-authenticated users accessing the system are assigned the name "anonymous". Assign permissions to the "anonymous" user to set privileges for anonymous/guest users. The parts of Trac that a user does not have the privileges for will not be displayed in the navigation.
    11 In addition to these privileges, users can be granted additional individual rights in effect when authenticated and logged into the system. All logged in users belong to the virtual group "authenticated", which inherits permissions from "anonymous".
     6Permissions are managed using the [TracAdmin trac-admin] tool or the ''General / Permissions'' panel in the ''Admin'' tab of the web interface.
     8In addition to the default permission policy described in this page, it is possible to activate additional permission policies by enabling plugins and listing them in [TracIni#trac-permission_policies-option "[trac] permission_policies"]. See TracFineGrainedPermissions for more details.
     10Non-authenticated users accessing the system are assigned the name //anonymous//. Assign permissions to the //anonymous// user to set privileges for anonymous/guest users. The parts of Trac that a user does not have privilege for will not be displayed in the navigation.
     11In addition to these privileges, users can be granted additional individual rights in effect when authenticated and logged into the system. All logged in users belong to the virtual group //authenticated//, which inherits permissions from //anonymous//.
    1212
    1313== Graphical Admin Tab
    1414
    15 To access this tab, a user must have one of the following permissions: `TRAC_ADMIN`, `PERMISSION_ADMIN`, `PERMISSION_GRANT`, `PERMISSION_REVOKE`. The permissions can be granted using the `trac-admin` command (more on `trac-admin` below):
    16 {{{
    17   $ trac-admin /path/to/projenv permission add bob TRAC_ADMIN
    18 }}}
    19
    20 Then, the user `bob` will be able to see the Admin tab, and can then access the permissions menu. This menu will allow you to perform all the following actions, but from the browser without requiring root access to the server (just the correct permissions for your user account). '''Use at least one lowercase character in user names, as all-uppercase names are reserved for permissions.'''
    21
    22  1. [[Image(htdocs:../common/guide/admin.png)]]
    23  1. [[Image(htdocs:../common/guide/admin-permissions.png)]]
    24  1. [[Image(htdocs:../common/guide/admin-permissions-TICKET_ADMIN.png)]]
    25
    26 An easy way to quickly secure a new Trac install is to run the above command on the anonymous user, install the [http://trac-hacks.org/wiki/AccountManagerPlugin AccountManagerPlugin], create a new admin account graphically and then remove the TRAC_ADMIN permission from the anonymous user.
     15To access this tab, a user must have one of the following permissions: `TRAC_ADMIN`, `PERMISSION_ADMIN`, `PERMISSION_GRANT`, `PERMISSION_REVOKE`. The permissions can be granted using the `trac-admin` command with a more detailed description [#GrantingPrivileges below]:
     16{{{#!sh
     17$ trac-admin /path/to/projenv permission add bob TRAC_ADMIN
     18}}}
     19
     20Then, the user `bob` will be able to see the Admin tab, and can access the permissions menu. This menu will allow you to perform all the following actions, but from the browser rather than requiring root access to the server. '''Use at least one lowercase character in user names, as all-uppercase names are reserved for permissions.'''
     21
     22[[Image(htdocs:../common/guide/admin.png)]]
     23
     24[[Image(htdocs:../common/guide/admin-permissions.png)]]
     25
     26[[Image(htdocs:../common/guide/admin-permissions-TICKET_ADMIN.png)]]
    2727
    2828From the graphical admin tab, users with `PERMISSION_GRANT` will only be allowed to grant permissions that they possess, and users with `PERMISSION_REVOKE` will only be allowed to revoke permissions that they possess. For example, a user cannot grant `MILESTONE_ADMIN` unless they have `PERMISSION_GRANT` and `MILESTONE_ADMIN`, and they cannot revoke `MILESTONE_ADMIN` unless they have `PERMISSION_REVOKE` and `MILESTONE_ADMIN`. `PERMISSION_ADMIN` just grants the user both `PERMISSION_GRANT` and `PERMISSION_REVOKE`, and users with `TRAC_ADMIN` can grant or revoke any permission.
    3030== Available Privileges
    3131
    32 To enable all privileges for a user, use the `TRAC_ADMIN` permission. Having `TRAC_ADMIN` is like being `root` on a *NIX system: it will allow you to perform any operation.
    34 Otherwise, individual privileges can be assigned to users for the various different functional areas of Trac ('''note that the privilege names are case-sensitive'''):
     32To enable all privileges for a user, use the `TRAC_ADMIN` permission. This permission is like being `root` on a *NIX system: it will allow you to perform any operation.
     34Otherwise, individual privileges can be assigned to users for the different functional areas of Trac and '''note that the privilege names are uppercase''':
    3535
    3636=== Repository Browser
    3737
    38 || `BROWSER_VIEW` || View directory listings in the [wiki:TracBrowser repository browser] ||
    39 || `LOG_VIEW` || View revision logs of files and directories in the [wiki:TracBrowser repository browser] ||
    40 || `FILE_VIEW` || View files in the [wiki:TracBrowser repository browser] ||
    41 || `CHANGESET_VIEW` || View [wiki:TracChangeset repository check-ins] ||
     38|| `BROWSER_VIEW` || View directory listings in the [TracBrowser repository browser] ||
     39|| `FILE_VIEW` || View files in the [TracBrowser repository browser] ||
     40|| `CHANGESET_VIEW` || View [TracChangeset repository check-ins] ||
     41|| `LOG_VIEW` || View revision logs of files and directories in the [TracBrowser repository browser] ||
    4242
    4343=== Ticket System
    4444
    45 || `TICKET_VIEW` || View existing [wiki:TracTickets tickets] and perform [wiki:TracQuery ticket queries] ||
    46 || `TICKET_CREATE` || Create new [wiki:TracTickets tickets] ||
    47 || `TICKET_APPEND` || Add comments or attachments to [wiki:TracTickets tickets] ||
    48 || `TICKET_CHGPROP` || Modify [wiki:TracTickets ticket] properties (priority, assignment, keywords, etc.) with the following exceptions: edit description field, add/remove other users from cc field when logged in, and set email to pref ||
    49 || `TICKET_MODIFY` || Includes both `TICKET_APPEND` and `TICKET_CHGPROP`, and in addition allows resolving [wiki:TracTickets tickets]. Tickets can be assigned to users through a [TracTickets#Assign-toasDrop-DownList drop-down list] when the list of possible owners has been restricted. ||
     45|| `TICKET_VIEW` || View existing [TracTickets tickets] and perform [TracQuery ticket queries] ||
     46|| `TICKET_CREATE` || Create new [TracTickets tickets] ||
     47|| `TICKET_APPEND` || Add comments and attachments to [TracTickets tickets], and edit description of ticket the user created ||
     48|| `TICKET_CHGPROP` || Modify [TracTickets ticket] properties (priority, assignment, keywords, etc.) with the following exceptions: edit description of tickets created by others, add/remove other users from cc field when logged in ||
     49|| `TICKET_MODIFY` || Includes both `TICKET_APPEND` and `TICKET_CHGPROP`, and in addition allows resolving [TracTickets tickets] in the [TracWorkflow default workflow]. Tickets can be assigned to users through a [TracTickets#Assign-toasDrop-DownList drop-down list] when the list of possible owners has been restricted. ||
    5050|| `TICKET_EDIT_CC` || Full modify cc field ||
    51 || `TICKET_EDIT_DESCRIPTION` || Modify description field ||
     51|| `TICKET_EDIT_DESCRIPTION` || Modify description field. User with `TICKET_APPEND` or `TICKET_CHGPROP` can modify description of ticket they created. ||
    5252|| `TICKET_EDIT_COMMENT` || Modify another user's comments. Any user can modify their own comments by default. ||
    53 || `TICKET_BATCH_MODIFY` || [wiki:TracBatchModify Batch modify] tickets ||
    54 || `TICKET_ADMIN` || All `TICKET_*` permissions, deletion of ticket attachments and modification of the reporter field, which grants ability to create a ticket on behalf of another user (it will appear that another user created the ticket). It also allows managing ticket properties through the web administration module. ||
    56 Attention: the "view tickets" button appears with the `REPORT_VIEW` permission.
     53|| `TICKET_BATCH_MODIFY` || [TracBatchModify Batch modify] tickets ||
     54|| `TICKET_ADMIN` || All `TICKET_*` permissions, deletion of ticket attachments and modification of the reporter field, which grants ability to create a ticket on behalf of another user and it will appear that another user created the ticket. It also allows managing ticket properties through the web administration module. ||
    5755
    5856=== Roadmap
    5957
    6058|| `MILESTONE_VIEW` || View milestones and assign tickets to milestones. ||
    61 || `MILESTONE_CREATE` || Create a new milestone ||
    62 || `MILESTONE_MODIFY` || Modify existing milestones ||
     59|| `MILESTONE_CREATE` || Create new milestones ||
     60|| `MILESTONE_MODIFY` || Modify milestones ||
    6361|| `MILESTONE_DELETE` || Delete milestones ||
    6462|| `MILESTONE_ADMIN` || All `MILESTONE_*` permissions ||
    65 || `ROADMAP_VIEW` || View the [wiki:TracRoadmap roadmap] page, is not (yet) the same as MILESTONE_VIEW, see [trac:#4292 #4292] ||
     63|| `ROADMAP_VIEW` || View the [TracRoadmap roadmap] page, which is not yet the same as MILESTONE_VIEW, see [trac:#4292 #4292] ||
    6664|| `ROADMAP_ADMIN` || to be removed with [trac:#3022 #3022], replaced by MILESTONE_ADMIN ||
    6765
    6866=== Reports
    6967
    70 || `REPORT_VIEW` || View [wiki:TracReports reports], i.e. the "view tickets" link. ||
    71 || `REPORT_SQL_VIEW` || View the underlying SQL query of a [wiki:TracReports report] ||
    72 || `REPORT_CREATE` || Create new [wiki:TracReports reports] ||
    73 || `REPORT_MODIFY` || Modify existing [wiki:TracReports reports] ||
    74 || `REPORT_DELETE` || Delete [wiki:TracReports reports] ||
     68|| `REPORT_VIEW` || View [TracReports reports], i.e. the //View Tickets// link. ||
     69|| `REPORT_SQL_VIEW` || View the SQL query of a [TracReports report] ||
     70|| `REPORT_CREATE` || Create new [TracReports reports] ||
     71|| `REPORT_MODIFY` || Modify [TracReports reports] ||
     72|| `REPORT_DELETE` || Delete [TracReports reports] ||
    7573|| `REPORT_ADMIN` || All `REPORT_*` permissions ||
    7674
    7775=== Wiki System
    7876
    79 || `WIKI_VIEW` || View existing [wiki:TracWiki wiki] pages ||
    80 || `WIKI_CREATE` || Create new [wiki:TracWiki wiki] pages ||
    81 || `WIKI_MODIFY` || Change [wiki:TracWiki wiki] pages ||
    82 || `WIKI_RENAME` || Rename [wiki:TracWiki wiki] pages ||
    83 || `WIKI_DELETE` || Delete [wiki:TracWiki wiki] pages and attachments ||
     77|| `WIKI_VIEW` || View [TracWiki wiki] pages ||
     78|| `WIKI_CREATE` || Create new [TracWiki wiki] pages ||
     79|| `WIKI_MODIFY` || Modify [TracWiki wiki] pages ||
     80|| `WIKI_RENAME` || Rename [TracWiki wiki] pages ||
     81|| `WIKI_DELETE` || Delete [TracWiki wiki] pages and attachments ||
    8482|| `WIKI_ADMIN` || All `WIKI_*` permissions, plus the management of ''readonly'' pages. ||
    8583
    9290=== Others
    9391
    94 || `TIMELINE_VIEW` || View the [wiki:TracTimeline timeline] page ||
    95 || `SEARCH_VIEW` || View and execute [wiki:TracSearch search] queries ||
    96 || `CONFIG_VIEW` || Enables additional pages on ''About Trac'' that show the current configuration or the list of installed plugins ||
    97 || `EMAIL_VIEW` || Shows email addresses even if [wiki:TracIni#trac-section trac show_email_addresses] configuration option is false ||
    98
    99 == Creating New Privileges
    100
    101 To create custom permissions, for example to be used in a custom workflow, enable the optional [trac:ExtraPermissionsProvider tracopt.perm.config_perm_provider.ExtraPermissionsProvider] component in the "Plugins" admin panel, and add the desired permissions to the `[extra-permissions]` section in your [wiki:TracIni#extra-permissions-section trac.ini]. For more information, please refer to the documentation  on the [wiki:TracIni#extra-permissions-section TracIni] page after enabling the component.
     92|| `TIMELINE_VIEW` || View the [TracTimeline timeline] page ||
     93|| `SEARCH_VIEW` || View and execute [TracSearch search] queries ||
     94|| `CONFIG_VIEW` || Enables additional sections on ''About Trac'' that show the current configuration and the list of installed plugins ||
     95|| `EMAIL_VIEW` || Shows email addresses even if [TracIni#trac-section trac show_email_addresses] configuration option is false ||
     96
     97== Attachment Permissions
     98
     99Attachment permissions are handled by `LegacyAttachmentPolicy`, and unlike the permissions discussed so far, the permissions provided by `LegacyAttachmentPolicy` are not directly granted. Rather, the ability to create, view and delete attachments is determined by the attachment's parent realm and permissions the user possesses for that realm.
     100
     101The attachment actions are determined by the following
     102permissions in the ticket, wiki and milestone realms:
     103{{{#!table class="listing"
     104||= Granted By: =||= Ticket =||= Wiki =||= Milestone =||
     105|| `ATTACHMENT_CREATE` || `TICKET_APPEND` || `WIKI_MODIFY` || `MILESTONE_MODIFY` ||
     106|| `ATTACHMENT_VIEW` || `TICKET_VIEW` || `WIKI_VIEW` || `MILESTONE_VIEW` ||
     107|| `ATTACHMENT_DELETE` || `TICKET_ADMIN` || `WIKI_DELETE` || `MILESTONE_DELETE` ||
     108}}}
     109
     110An authenticated user can delete an attachment //they added// without possessing the permission
     111that grants `ATTACHMENT_DELETE`.
     112
     113If explicit attachment permissions are preferred, `ATTACHMENT_CREATE`, `ATTACHMENT_DELETE` and `ATTACHMENT_VIEW` can be created using the [trac:ExtraPermissionsProvider]. The simplest implementation is to simply define the actions.
     114{{{#!ini
     115[extra-permissions]
     116_perms = ATTACHMENT_CREATE, ATTACHMENT_DELETE, ATTACHMENT_VIEW
     117}}}
     118
     119An alternative configuration adds an `ATTACHMENT_ADMIN` meta-permission that grants the other 3 permission.
     120{{{#!ini
     121[extra-permissions]
     122ATTACHMENT_ADMIN = ATTACHMENT_CREATE, ATTACHMENT_DELETE, ATTACHMENT_VIEW
     123}}}
     124
     125The explicit permissions can be used in concert with `LegacyAttachmentPolicy`, or `LegacyAttachmentPolicy` can be removed from `permission_policies`, in which case only users that have been explicitly granted the corresponding attachment actions will be able to create, delete and view attachments.
    102126
    103127== Granting Privileges
    104128
    105 You grant privileges to users using [wiki:TracAdmin trac-admin]. The current set of privileges can be listed with the following command:
    106 {{{
    107   $ trac-admin /path/to/projenv permission list
     129You grant privileges to users using [TracAdmin trac-admin]. The current set of privileges can be listed with the following command:
     130{{{#!sh
     131$ trac-admin /path/to/projenv permission list
    108132}}}
    109133
    110134This command will allow the user ''bob'' to delete reports:
    111 {{{
    112   $ trac-admin /path/to/projenv permission add bob REPORT_DELETE
     135{{{#!sh
     136$ trac-admin /path/to/projenv permission add bob REPORT_DELETE
    113137}}}
    114138
    115139The `permission add` command also accepts multiple privilege names:
    116 {{{
    117   $ trac-admin /path/to/projenv permission add bob REPORT_DELETE WIKI_CREATE
     140{{{#!sh
     141$ trac-admin /path/to/projenv permission add bob REPORT_DELETE WIKI_CREATE
    118142}}}
    119143
    120144Or add all privileges:
    121 {{{
    122   $ trac-admin /path/to/projenv permission add bob TRAC_ADMIN
     145{{{#!sh
     146$ trac-admin /path/to/projenv permission add bob TRAC_ADMIN
    123147}}}
    124148
    125149== Permission Groups
    126150
    127 There are two built-in groups, "authenticated" and "anonymous".
    128 Any user who has not logged in is automatically in the "anonymous" group.
    129 Any user who has logged in is also in the "authenticated" group.
    130 The "authenticated" group inherits permissions from the "anonymous" group.
    131 For example, if the "anonymous" group has permission WIKI_MODIFY,
    132 it is not necessary to add the WIKI_MODIFY permission to the "authenticated" group as well.
     151There are two built-in groups, //authenticated// and //anonymous//.
     152Any user who has not logged in is automatically in the //anonymous// group.
     153Any user who has logged in is also in the //authenticated// group.
     154The //authenticated// group inherits permissions from the //anonymous// group.
     155For example, if the //anonymous// group has permission WIKI_MODIFY, it is not necessary to add the WIKI_MODIFY permission to the //authenticated// group as well.
    133156
    134157Custom groups may be defined that inherit permissions from the two built-in groups.
    135158
    136159Permissions can be grouped together to form roles such as ''developer'', ''admin'', etc.
    137 {{{
    138   $ trac-admin /path/to/projenv permission add developer WIKI_ADMIN
    139   $ trac-admin /path/to/projenv permission add developer REPORT_ADMIN
    140   $ trac-admin /path/to/projenv permission add developer TICKET_MODIFY
    141   $ trac-admin /path/to/projenv permission add bob developer
    142   $ trac-admin /path/to/projenv permission add john developer
     160{{{#!sh
     161$ trac-admin /path/to/projenv permission add developer WIKI_ADMIN
     162$ trac-admin /path/to/projenv permission add developer REPORT_ADMIN
     163$ trac-admin /path/to/projenv permission add developer TICKET_MODIFY
     164$ trac-admin /path/to/projenv permission add bob developer
     165$ trac-admin /path/to/projenv permission add john developer
    143166}}}
    144167
    148171Permission groups can be created by assigning a user to a group you wish to create, then assign permissions to that group.
    149172
    150 The following will add ''bob'' to the new group called ''beta_testers'' and then will assign WIKI_ADMIN permissions to that group. (Thus, ''bob'' will inherit the WIKI_ADMIN permission)
    151 {{{
    152    $ trac-admin /path/to/projenv permission add bob beta_testers
    153    $ trac-admin /path/to/projenv permission add beta_testers WIKI_ADMIN
    154
     173The following will add ''bob'' to the new group called ''beta_testers'' and then will assign `WIKI_ADMIN` permissions to that group. Thus, ''bob'' will inherit the `WIKI_ADMIN` permission.
     174{{{#!sh
     175$ trac-admin /path/to/projenv permission add bob beta_testers
     176$ trac-admin /path/to/projenv permission add beta_testers WIKI_ADMIN
    155177}}}
    156178
    157179== Removing Permissions
    158180
    159 Permissions can be removed using the 'remove' command. For example:
     181Permissions can be removed using the 'remove' command.
    160182
    161183This command will prevent the user ''bob'' from deleting reports:
     184{{{#!sh
     185$ trac-admin /path/to/projenv permission remove bob REPORT_DELETE
     186}}}
     187
     188Just like `permission add`, this command accepts multiple privilege names.
     189
     190You can also remove all privileges for a specific user:
     191{{{#!sh
     192$ trac-admin /path/to/projenv permission remove bob '*'
     193}}}
     194
     195Or one privilege for all users:
     196{{{#!sh
     197$ trac-admin /path/to/projenv permission remove '*' REPORT_ADMIN
     198}}}
     199
     200== Creating New Privileges
     201
     202To create custom permissions, for example to be used in a custom workflow, enable the optional [trac:ExtraPermissionsProvider tracopt.perm.config_perm_provider.ExtraPermissionsProvider] component in the "Plugins" admin panel, and add the desired permissions to the `[extra-permissions]` section in your [TracIni#extra-permissions-section trac.ini]. For more information, please refer to the documentation  on the [TracIni#extra-permissions-section TracIni] page after enabling the component.
     203
     204== Default Permissions
     205
     206By default on a new Trac installation, the //anonymous// user will have ''view'' access to everything in Trac, but will not be able to create or modify anything.
     207On the other hand, the //authenticated// users will have the permissions to ''create and modify tickets and wiki pages''.
     208
     209//**anonymous**//
    162210{{{
    163   $ trac-admin /path/to/projenv permission remove bob REPORT_DELETE
    164 }}}
    165
    166 Just like `permission add`, this command accepts multiple privilege names.
    167
    168 You can also remove all privileges for a specific user:
     211BROWSER_VIEW
     212CHANGESET_VIEW
     213FILE_VIEW
     214LOG_VIEW
     215MILESTONE_VIEW
     216REPORT_SQL_VIEW
     217REPORT_VIEW
     218ROADMAP_VIEW
     219SEARCH_VIEW
     220TICKET_VIEW
     221TIMELINE_VIEW
     222WIKI_VIEW
     223}}}
     224
     225//**authenticated**//
    169226{{{
    170   $ trac-admin /path/to/projenv permission remove bob '*'
    171 }}}
    172
    173 Or one privilege for all users:
    174 {{{
    175   $ trac-admin /path/to/projenv permission remove '*' REPORT_ADMIN
    176 }}}
    177
    178 == Default Permissions
    179
    180 By default on a new Trac installation, the `anonymous` user will have ''view'' access to everything in Trac, but will not be able to create or modify anything.
    181 On the other hand, the `authenticated` users will have the permissions to ''create and modify tickets and wiki pages''.
    182
    183 '''anonymous'''
    184 {{{
    185  BROWSER_VIEW
    186  CHANGESET_VIEW
    187  FILE_VIEW
    188  LOG_VIEW
    189  MILESTONE_VIEW
    190  REPORT_SQL_VIEW
    191  REPORT_VIEW
    192  ROADMAP_VIEW
    193  SEARCH_VIEW
    194  TICKET_VIEW
    195  TIMELINE_VIEW
    196  WIKI_VIEW
    197 }}}
    198
    199 '''authenticated'''
    200 {{{
    201  TICKET_CREATE
    202  TICKET_MODIFY
    203  WIKI_CREATE
    204  WIKI_MODIFY
     227TICKET_CREATE
     228TICKET_MODIFY
     229WIKI_CREATE
     230WIKI_MODIFY
    205231}}}
    206232----
    207 See also: TracAdmin, TracGuide and TracFineGrainedPermissions
     233See also: TracAdmin, TracFineGrainedPermissions
