Changes between Version 4 and Version 5 of TracPermissions
09/05/24 03:39:01 (3 months ago)
  • TracPermissions
    v4 v5
    88In addition to the default permission policy described in this page, it is possible to activate additional permission policies by enabling plugins and listing them in [TracIni#trac-permission_policies-option "[trac] permission_policies"]. See TracFineGrainedPermissions for more details.
    10 Non-authenticated users accessing the system are assigned the name //anonymous//. Assign permissions to the //anonymous// user to set privileges for anonymous/guest users. The parts of Trac that a user does not have privilege for will not be displayed in the navigation.
     10Non-authenticated users accessing the system are assigned the name //anonymous//. Assign permissions to the //anonymous// user to set privileges for anonymous/guest users. The parts of Trac that a user does not have privileges for will not be displayed in the navigation bar.
    1111In addition to these privileges, users can be granted additional individual rights in effect when authenticated and logged into the system. All logged in users belong to the virtual group //authenticated//, which inherits permissions from //anonymous//.
    1212
    1818}}}
    1919
    20 Then, the user `bob` will be able to see the Admin tab, and can access the permissions menu. This menu will allow you to perform all the following actions, but from the browser rather than requiring root access to the server. '''Use at least one lowercase character in user names, as all-uppercase names are reserved for permissions.'''
     20Then, the user `bob` will be able to see the Admin tab, and can access the permissions menu. This menu allows you to perform the following actions, but from the browser rather than requiring root access to the server. '''Use at least one lowercase character in user names, as all-uppercase names are reserved for permissions.'''
    2121
    2222[[Image(htdocs:../common/guide/admin.png)]]
    3030== Available Privileges
    3131
    32 To enable all privileges for a user, use the `TRAC_ADMIN` permission. This permission is like being `root` on a *NIX system: it will allow you to perform any operation.
     32To enable all privileges for a user, use the `TRAC_ADMIN` permission. This permission is like being `root` on a *NIX system: it will allow you to perform any operation on Trac.
    3333
    3434Otherwise, individual privileges can be assigned to users for the different functional areas of Trac and '''note that the privilege names are uppercase''':
    4545|| `TICKET_VIEW` || View existing [TracTickets tickets] and perform [TracQuery ticket queries] ||
    4646|| `TICKET_CREATE` || Create new [TracTickets tickets] ||
    47 || `TICKET_APPEND` || Add comments and attachments to [TracTickets tickets], and edit description of ticket the user created ||
     47|| `TICKET_APPEND` || Add comments and attachments to [TracTickets tickets], and edit description of ticket that the user created ||
    4848|| `TICKET_CHGPROP` || Modify [TracTickets ticket] properties (priority, assignment, keywords, etc.) with the following exceptions: edit description of tickets created by others, add/remove other users from cc field when logged in ||
    4949|| `TICKET_MODIFY` || Includes both `TICKET_APPEND` and `TICKET_CHGPROP`, and in addition allows resolving [TracTickets tickets] in the [TracWorkflow default workflow]. Tickets can be assigned to users through a [TracTickets#Assign-toasDrop-DownList drop-down list] when the list of possible owners has been restricted. ||
    6262|| `MILESTONE_ADMIN` || All `MILESTONE_*` permissions ||
    6363|| `ROADMAP_VIEW` || View the [TracRoadmap roadmap] page, which is not yet the same as MILESTONE_VIEW, see [trac:#4292 #4292] ||
    64 || `ROADMAP_ADMIN` || to be removed with [trac:#3022 #3022], replaced by MILESTONE_ADMIN ||
     64|| `ROADMAP_ADMIN` || To be removed with [trac:#3022 #3022], replaced by MILESTONE_ADMIN ||
    6565
    6666=== Reports
    9797== Attachment Permissions
    9898
    99 Attachment permissions are handled by `LegacyAttachmentPolicy`, and unlike the permissions discussed so far, the permissions provided by `LegacyAttachmentPolicy` are not directly granted. Rather, the ability to create, view and delete attachments is determined by the attachment's parent realm and permissions the user possesses for that realm.
    100
    101 The attachment actions are determined by the following
    102 permissions in the ticket, wiki and milestone realms:
     99Attachment permissions are handled by `LegacyAttachmentPolicy`, and unlike the permissions discussed so far, the permissions provided by `LegacyAttachmentPolicy` are not directly granted. Rather, the ability to create, view and delete attachments is determined by the attachment's parent realm and permissions that the user possesses for that realm.
     100
     101The attachment actions are determined by the following permissions in the ticket, wiki and milestone realms:
    103102{{{#!table class="listing"
    104103||= Granted By: =||= Ticket =||= Wiki =||= Milestone =||
    108107}}}
    109108
    110 An authenticated user can delete an attachment //they added// without possessing the permission
    111 that grants `ATTACHMENT_DELETE`.
    112
    113 If explicit attachment permissions are preferred, `ATTACHMENT_CREATE`, `ATTACHMENT_DELETE` and `ATTACHMENT_VIEW` can be created using the [trac:ExtraPermissionsProvider]. The simplest implementation is to simply define the actions.
     109An authenticated user can delete an attachment //they added// without possessing the permission that grants `ATTACHMENT_DELETE`.
     110
     111If explicit attachment permissions are preferred, then `ATTACHMENT_CREATE`, `ATTACHMENT_DELETE` and `ATTACHMENT_VIEW` can be created using the [trac:ExtraPermissionsProvider]. The simplest implementation is to simply define the actions:
    114112{{{#!ini
    115113[extra-permissions]
    117115}}}
    118116
    119 An alternative configuration adds an `ATTACHMENT_ADMIN` meta-permission that grants the other 3 permission.
     117An alternative configuration adds an `ATTACHMENT_ADMIN` meta-permission that grants the other 3 permissions:
    120118{{{#!ini
    121119[extra-permissions]
    123121}}}
    124122
    125 The explicit permissions can be used in concert with `LegacyAttachmentPolicy`, or `LegacyAttachmentPolicy` can be removed from `permission_policies`, in which case only users that have been explicitly granted the corresponding attachment actions will be able to create, delete and view attachments.
     123The explicit permissions can be used in conjunction with `LegacyAttachmentPolicy`, or `LegacyAttachmentPolicy` can be removed from `permission_policies`, in which case only users that have been explicitly granted the corresponding attachment actions will be able to create, delete and view attachments.
    126124
    127125== Granting Privileges
    128126
    129 You grant privileges to users using [TracAdmin trac-admin]. The current set of privileges can be listed with the following command:
     127Privileges are granted to users through [TracAdmin trac-admin]. The current set of privileges can be listed with the following command:
    130128{{{#!sh
    131129$ trac-admin /path/to/projenv permission list
    153151Any user who has logged in is also in the //authenticated// group.
    154152The //authenticated// group inherits permissions from the //anonymous// group.
    155 For example, if the //anonymous// group has permission WIKI_MODIFY, it is not necessary to add the WIKI_MODIFY permission to the //authenticated// group as well.
     153For example, if the //anonymous// group has permission `WIKI_MODIFY`, it is not necessary to add the `WIKI_MODIFY` permission to the //authenticated// group as well.
    156154
    157155Custom groups may be defined that inherit permissions from the two built-in groups.
    169167
    170168== Adding a New Group and Permissions
     169
    171170Permission groups can be created by assigning a user to a group you wish to create, then assign permissions to that group.
    172171
    204203== Default Permissions
    205204
    206 By default on a new Trac installation, the //anonymous// user will have ''view'' access to everything in Trac, but will not be able to create or modify anything.
    207 On the other hand, the //authenticated// users will have the permissions to ''create and modify tickets and wiki pages''.
     205By default on a new Trac installation, the //anonymous// user has ''view'' access to everything in Trac, but is not able to create or modify anything.
     206The //authenticated// user has the permissions to ''create and modify tickets and wiki pages''.
    208207
    209208//**anonymous**//
    230229WIKI_MODIFY
    231230}}}
     231
    232232----
    233233See also: TracAdmin, TracFineGrainedPermissions
