Changes between Initial Version and Version 1 of TracRevisionLog
05/15/08 12:30:24 (17 years ago)
  • TracRevisionLog
     1= Viewing Revision Logs =
     2[[TracGuideToc]]
     4When you browse the repository, it's always possible to query the
     5''Revision Log'' view corresponding to the path you're currently seeing.
     6This will display a list of the most recent changesets in which the
     7current path or any other path below it has been modified.
     8
     9== The Revision Log Form ==
     10
     11It's possible to set the revision at which the revision log should
     12start, using the ''View log starting at'' field. An empty value
     13or a value of ''head'' is taken to be the newest changeset.
     14
     15It's also possible to specify the revision at which the log should
     16stop, using the ''back to'' field. By default, it's left empty,
     17which means the revision log will stop as soon as 100 revisions have
     18been listed.
     19
     20Also, there are three modes of operation of the revision log.
     21
     22By default, the revision log ''stops on copy'', which means that
     23whenever an ''Add'', ''Copy'' or ''Rename'' operation is detected,
     24no older revision will be shown. That's very convenient when working
     25with branches, as one only sees the history corresponding to what
     26has been done on the branch.
     27
     28It's also possible to indicate that one wants to see what happened
     29before a ''Copy'' or ''Rename'' change, by selecting the
     30''Follow copies'' mode. This will cross all copies or renames changes.
     31Each time the name of the path changes, there will be an additional
     32indentation level. That way, the changes on the different paths
     33are easily grouped together visually.
     34
     35It's even possible to go past an ''Add'' change, in order to see
     36if there has been a ''Delete'' change on that path, before
     37that ''Add''. This mode corresponds to the mode called
     38''Show only adds, moves and deletes''.
     39While quite useful at times, be aware that this operation is quite
     40resource intensive.
     41
     42Finally, there's also a checkbox ''Show full log messages'',
     43which controls whether the full content of the commit log message
     44should be displayed for each change, or only a shortened version of it.
     45
     46== The Revision Log Information ==
     47
     48For each revision log entry, there are 7 columns shown:
     49 1. The first column contains a pair of radio buttons and should used
     50    for selecting the ''old'' and the ''new'' revisions that will be
     51    used for [wiki:TracRevisionLog#viewingtheactualchanges viewing the actual changes].
     52 2. A color code (similar to the one used for the [wiki:TracChangeset#ChangesetHeader changesets])
     53    indicating kind of change.
     54    Clicking on this column refreshes the revision log so that it restarts
     55    with this change.
     56 3. The '''Date''' at which the change was made.
     57 4. The '''Revision''' number, displayed as `@xyz`.
     58    This is a link to the TracBrowser, using that revision as the base line.
     59 5. The '''Changeset''' number, displayed as `[xyz]`.
     60    This is a link to the TracChangeset view.
     61 6. The '''Author''' of the change.
     62 7. The '''Log Message''', which contains either a summary or the full commit
     63    log message, depending on the value of the ''Show full log messages''
     64    checkbox in the form above.
     65
     66
     67== Inspecting Changes Between Revisions ==
     68
     69The ''View changes...'' buttons (placed above and below the list
     70of changes, on the left side) will show the set of differences
     71corresponding to the aggregated changes starting from the ''old''
     72revision (first radio-button) to the ''new'' revision (second
     73radio-button), in the TracChangeset view.
     74
     75Note that the ''old'' revision doesn't need to be actually
     76''older'' than the ''new'' revision: it simply gives a base
     77for the diff. It's therefore entirely possible to easily
     78generate a ''reverse diff'', for reverting what has been done
     79in the given range of revisions.
     80
     81Finally, if the two revisions are identical, the corresponding
     82changeset will be shown (same effect as clicking on column 5).
     83
     84== Alternative Formats ==
     85
     86=== The ChangeLog Text ===
     87
     88At the bottom of the page, there's a ''ChangeLog'' link
     89that will show the range of revisions as currently shown,
     90but as a simple text, matching the usual conventions for
     91!ChangeLog files.
     92
     93=== RSS Support ===
     94
     95The revision log also provides a RSS feed to monitor the changes.
     96To subscribe to a RSS feed for a file or directory, open its
     97revision log in the browser and click the orange 'XML' icon at the bottom
     98of the page. For more information on RSS support in Trac, see TracRss.
     100----
     101See also: TracBrowser, TracChangeset, TracGuide
