Changes between Version 4 and Version 5 of TracWorkflow
09/05/24 03:39:02 (3 months ago)
  • TracWorkflow
    v4 v5
    33[[PageOutline(2-5,Contents,pullout)]]
    44[[TracGuideToc]]
    5 The Trac ticket system provides a configurable workflow.
     6The Trac ticket system provides a configurable workflow on how tickets are treated.
    67
    78== The Default Ticket Workflow
    89
    9 When a new environment is created, a default workflow is configured in your trac.ini. This workflow is the basic workflow, as specified in [trac:source:branches/1.4-stable/trac/ticket/workflows/basic-workflow.ini basic-workflow.ini]:
     10When a new environment is created, a default workflow is configured in your `trac.ini`. This workflow is the basic workflow, as specified in [trac:source:branches/1.4-stable/trac/ticket/workflows/basic-workflow.ini basic-workflow.ini]:
    1011
    1112{{{#!Workflow width=700 height=300
    6263The `accept.permissions` line specifies the permissions the user must have to use this action. [trac:ExtraPermissionsProvider] can define new permissions to be used here.
    6364
    64 The `accept.operations` line specifies changes that will be made to the ticket in addition to the status change when the action is taken.  In this case, when a user clicks on `accept`, the ticket owner field is updated to the logged in user. Multiple operations may be specified in a comma separated list.
     65The `accept.operations` line specifies changes that will be made to the ticket in addition to the status change when the action is taken. In this case, when a user clicks on `accept`, the ticket owner field is updated to the logged in user. Multiple operations may be specified in a comma separated list.
    6566
    6667The available operations are:
    158159== Example: Adding optional Testing with Workflow
    159160
    160 The following adds a `testing` action. When the ticket has status `new`, `accepted` or `needs_work`, you can choose to submit it for testing.  When it's in the testing status the user gets the option to reject it and send it back to `needs_work`, or pass the testing and send it along to `closed`. If they accept it, then it is automatically marked as `closed` and the resolution is set to `fixed`. Since all the old work flow remains, a ticket can skip this entire section.
     161The following adds a `testing` action. When the ticket has status `new`, `accepted` or `needs_work`, you can choose to submit it for testing. When it's in the testing status the user gets the option to reject it and send it back to `needs_work`, or pass the testing and send it along to `closed`. If they accept it, then it is automatically marked as `closed` and the resolution is set to `fixed`. Since all the old workflow remains, a ticket can skip this entire section.
    161162
    162163{{{#!ini
    249250== Ideas for next steps
    250251
    251 Enhancement ideas for the workflow system should be filed as enhancement tickets against the [trac:query:?status=assigned&status=new&status=reopened&keywords=~workflow&component=ticket+system ticket system] component.  You can also document ideas on the [trac:TracIdeas/TracWorkflow TracIdeas/TracWorkflow] page.
     252Enhancement ideas for the workflow system should be filed as enhancement tickets against the [trac:query:?status=assigned&status=new&status=reopened&keywords=~workflow&component=ticket+system ticket system] component. You can also document ideas on the [trac:TracIdeas/TracWorkflow TracIdeas/TracWorkflow] page.
