Changes between Initial Version and Version 1 of WikiHtml
05/15/08 12:30:24 (17 years ago)
  • WikiHtml
     1= Using HTML in Wiki Text =
     3Trac supports inserting HTML into any wiki context, accomplished using the HTML [wiki:WikiProcessors WikiProcessor].
     5HTML support is built-in, and does not require installing any additional packages.
     7== How to Use HTML ==
     8To inform the wiki engine that a block of text should be treated as HTML, use the ''html'' processor.
     10This example should explain:
     11{{{
     12#!html
     13<pre class="wiki">{{{
     14#!html
     15&lt;h1 style="text-align: right; color: blue"&gt;HTML Test&lt;/h1&gt;
     16}}}</pre>
     17}}}
     18
     19Results in:
     20{{{
     21#!html
     22<h1 style="text-align: right; color: blue">HTML Test</h1>
     23}}}
     25Note that Trac sanitizes your HTML code before displaying it. That means that if you try to use potentially dangerous constructs such as Javascript event handlers, those will be removed from the output.
     27== More Information ==
     28
     29 * http://www.w3.org/ -- World Wide Web Consortium
     30 * http://www.w3.org/MarkUp/ -- HTML Markup Home Page
     31
     32----
     33See also:  WikiProcessors, WikiFormatting, WikiRestructuredText
