Changes between Version 1 and Version 2 of WikiPageNames
- 06/10/10 13:36:18 (15 years ago)
WikiPageNames
v1 v2 1 1 = Wiki Page Names = 2 [[TracGuideToc]] 2 3 3 4 Wiki page names commonly use the CamelCase convention. Within wiki text, any word in CamelCase automatically becomes a hyperlink to the wiki page with that name. … … 21 22 * [wiki:Wiki_page], [wiki:ISO9000] 22 23 * [wiki:"Space Matters"] that page name embeds space characters 23 * or simply ["WikiPageName"] (!MoinMoin's internal free links style) 24 * or simply: ["WikiPageName"]s (!MoinMoin's internal free links style) 25 26 Starting with Trac 0.11, it's also possible to link to a specific ''version'' of a Wiki page, as you would do for a specific version of a file, for example: WikiStart@1. 24 27 25 28 See also TracLinks#QuotingspaceinTracLinks. 26 29 27 Finally, and as exemplified in the line above, one can also append an anchor to a Wiki page name, in order to link to a specific section within that page. The anchor can easily be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it's also possible to specify it explicit ely, see WikiFormatting#using-explicit-id-in-heading30 Finally, and as exemplified in the line above, one can also append an anchor to a Wiki page name, in order to link to a specific section within that page. The anchor can easily be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it's also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading. 28 31 ---- 29 32 See also: WikiNewPage, WikiFormatting, TracWiki, TracLinks
