Changes between Version 1 and Version 2 of WikiRestructuredText
06/10/10 13:36:18 (14 years ago)
  • WikiRestructuredText
    v1 v2
    66 "''reStructuredText is an easy-to-read, what-you-see-is-what-you-get plaintext markup syntax and parser   system. It is useful for in-line program documentation (such as Python docstrings), for quickly creating  simple web pages, and for standalone documents. reStructuredText is designed for extensibility for  specific application domains. ''"
     8If you want a file from your Subversion repository be displayed as reStructuredText in Trac's source browser, set `text/x-rst` as value for the Subversion property `svn:mime-type`. See [trac:source:/trunk/INSTALL this example].
    810=== Requirements ===
    911Note that to activate RST support in Trac, the python docutils package must be installed.
    1012If not already available on your operating system, you can download it at the [http://docutils.sourceforge.net/rst.html RST Website].
     13
     14Install docutils using `easy_install docutils`. Do not use the package manager of your OS (e.g. `apt-get install python-docutils`), because Trac will not find docutils then.
    1115
    1216=== More information on RST ===
    2226=== TracLinks in reStructuredText ===
    2327
    24  * Trac provides a custom RST reference-directive 'trac' to allow TracLinks from within RST text.
     28 * Trac provides a custom RST directive `trac::` to allow TracLinks from within RST text.
    2529
    2630 Example:
    3438 }}}
    3539
    36  For a complete example of all uses of the ''trac''-directive, please see WikiRestructuredTextLinks.
    37
    38
    39  * Trac allows an even easier way of creating TracLinks in RST, using the custom '':trac:'' link naming scheme.
     40 * Trac allows an even easier way of creating TracLinks in RST, using the custom `:trac:` role.
    4041
    4142 Example:
    4950 }}}
    5051
     52 For a complete example of all uses of the `:trac:` role, please see WikiRestructuredTextLinks.
     53
     54
    5155=== Syntax highlighting in reStructuredText ===
    5256
    53 There is a directive for doing TracSyntaxColoring in ReST as well. The directive is called
     57There is a directive for doing TracSyntaxColoring in RST as well. The directive is called
    5458code-block
    5559
    8488}}}
    8589
    86 === WikiMacros in reStructuredText ===
     90=== Wiki Macros in reStructuredText ===
    8791
    88 For doing WikiMacros in ReST you use the same directive as for syntax highlightning i.e
    89 code-block. To work you must use a version of trac that has #801 applied.
     92For doing [WikiMacros Wiki Macros] in RST you use the same directive as for syntax highlighting i.e
     93code-block. To work you must use a version of trac that has [trac:ticket:801 #801] applied.
    9094
    91 === WikiMacro Example ===
     95=== Wiki Macro Example ===
    9296
    9397{{{
    9599#!rst
    96100
    97 .. code-block:: HelloWorld
    98
    99    Something I wanted to say
     101.. code-block:: RecentChanges
    100102
     103   Trac,3
    101104
    102105}}}
    103106}}}
    104107
    105 Will result in the below.
     108Will result in the below:
    106109
    107 [[HelloWorld(Something I wanted to say)]]
     110     [[RecentChanges(Trac,3)]]
    108111
     112Or a more concise Wiki Macro like syntax is also available:
    109113
    110 === Bigger ReST Example ===
     114{{{
     115{{{
     116#!rst
     117
     118:code-block:`RecentChanges:Trac,3`
     119}}}
     120}}}
     121
     122=== Bigger RST Example ===
    111123The example below should be mostly self-explanatory:
    112124{{{
