Changes between Initial Version and Version 1 of Ticket #934
- 12/02/17 08:29:29 (7 years ago)
Ticket #934 – Description
initial v1 72 72 2. General: Adding source file/line number to the `<error>` element of to `apply_schema_test6_master.txt` 73 73 3. MySQL: Un-expected exception due to running a SQL query using a table name in incorrect case. 74 4. SqlServerSchemaMgrTests.testConfigError: Load an alternative configuration document for the test case that does not use OracleProvider schema mappings.
