Changes between Version 1 and Version 2 of Ticket #934
12/02/17 08:29:45 (7 years ago)
jng
  • Ticket #934 – Description
    v1 v2
    7171 1. General: Removing whitespace around certain master text files that are not present in the generated result
    7272 2. General: Adding source file/line number to the `<error>` element of to `apply_schema_test6_master.txt`
    73  3. MySQL: Un-expected exception due to running a SQL query using a table name in incorrect case.
     73 3. MySqlReaderTest.TestExceptionalCase: Un-expected exception due to running a SQL query using a table name in incorrect case.
    7474 4. SqlServerSchemaMgrTests.testConfigError: Load an alternative configuration document for the test case that does not use OracleProvider schema mappings.
