| 1 | [[PageOutline]] |
| 2 | |
| 3 | This page is an FDO Code Snippet. Visit the CodeSnippets page to view more! |
| 4 | |
| 5 | = Using batch insert = |
| 6 | |
| 7 | Using a batched insert is a more efficent method of inserting features in bulk instead of using the regular insert. For providers like KingOracle, batched inserts can be up to 10x faster than regular inserts. |
| 8 | |
| 9 | With a regular insert the process is as follows: |
| 10 | |
| 11 | 1. Create the IInsert command, set its feature class |
| 12 | 2. Add each value to insert as a PropertyValue into the command's PropertyValues collection, referencing the property name this value will be put into. |
| 13 | 3. Execute the command |
| 14 | |
| 15 | With a batched insert, the process is instead: |
| 16 | |
| 17 | 1. Create the IInsert command, set its feature class |
| 18 | 2. Add a parameter for each value that will be inserted as a batch into the command's PropertyValues collection |
| 19 | 3. For each feature to be inserted |
| 20 | a. Create a ParameterValueCollection |
| 21 | b. For each value in the feature to be inserted |
| 22 | i. Add a ParameterValue containing the value to insert and referencing the parameter to be inserted into (from step 2) |
| 23 | c. Add this ParameterValueCollection into the command's BatchParameterValues collection |
| 24 | 4. Execute the command |
| 25 | |
| 26 | The sample below illustrates this procedure with a list of Parcel objects. This assumes the feature source we are inserting into has the following feature class properties: |
| 27 | |
| 28 | * Name : string |
| 29 | * Address : string |
| 30 | * LandValue : double |
| 31 | |
| 32 | == C# Example == |
| 33 | |
| 34 | {{{ |
| 35 | #!cpp |
| 36 | |
| 37 | class Parcel |
| 38 | { |
| 39 | public string Name; |
| 40 | public string Address; |
| 41 | public double LandValue; |
| 42 | } |
| 43 | |
| 44 | ... |
| 45 | |
| 46 | IInsert insertCmd = ...; |
| 47 | List<Parcel> parcels = ...; |
| 48 | |
| 49 | //Add parameter PName as a placeholder for property "Name" |
| 50 | insertCmd.PropertyValues.Add(new PropertyValue("Name", new Parameter("PName"))); |
| 51 | //Add parameter PAddress as a placeholder for property "PAddress" |
| 52 | insertCmd.PropertyValues.Add(new PropertyValue("Address", new Parameter("PAddress"))); |
| 53 | //Add parameter PLandValue as a placeholder for property "PLandValue" |
| 54 | insertCmd.PropertyValues.Add(new PropertyValue("LandValue", new Parameter("PLandValue"))); |
| 55 | |
| 56 | //Loop through the list of parcels to insert |
| 57 | foreach(Parcel p in parcels) |
| 58 | { |
| 59 | ParameterValueCollection paramVals = new ParameterValueCollection(); |
| 60 | |
| 61 | //Insert the parcel's name under the parameter "PName" |
| 62 | paramVals.Add(new ParameterValue("PName", new StringValue(p.Name))); |
| 63 | |
| 64 | //Insert the parcel's address under the parameter "PAddress" |
| 65 | paramVals.Add(new ParameterValue("PAddress", new StringValue(p.Address))); |
| 66 | |
| 67 | //Insert the parcel's land value under the parameter "PLandValue" |
| 68 | paramVals.Add(new ParameterValue("PLandValue", new DoubleValue(p.LandValue))); |
| 69 | |
| 70 | insertCmd.BatchParameterValues.Add(paramVals); |
| 71 | } |
| 72 | |
| 73 | //Execute the batched insert |
| 74 | using(IFeatureReader reader = insertCmd.Execute()) |
| 75 | { |
| 76 | reader.Close(); |
| 77 | } |
| 78 | |
| 79 | }}} |
| 80 | |
