Changes between Version 1 and Version 2 of DockerRdbmsTestEnvironment
02/09/18 06:01:04 (7 years ago)
jng
Added a note about some one-time setup required for PostgreSQL
  • DockerRdbmsTestEnvironment
    v1 v2
    2626If your host OS is none of the above (eg. You are on Windows 7/8/8.1), you can use a virtual machine that is running one of the above OSes.
    2727
    28 = An example docker compose file =
     28== An example docker compose file ==
    2929
    3030With the `docker-compose` tool that comes with a docker installation, you can spin up all the required databases to hit your RDBMS provider test suites against.
    7272On subsequent runs, the images are not downloaded (as they have been downloaded locally)
    7373
     74== Some one-time PostgreSQL setup ==
     75
     76The PostgreSQL provider test suite assumes that `public` is the only schema of any PostGIS database it creates. The chosen docker image, while fully featured, breaks this assumption as it includes the `tiger` schema (for tiger geocoding), which the provider does not use, nor does the test suite exercise.
     78So before running the PostgreSQL test suite, use a tool like pgAdmin to connect to the PostGIS docker container and make sure to drop any schema that is not `public` from the `template_postgis` and `postgres` databases.
     79
     80This action only needs to be done once.
     81
     82Alternatively, you could try a different PostGIS docker image (or roll your own) that does not include these extraneous schemas in their PostGIS database setup.
     83
    7484== Running the GenericRdbms test suites against it ==
    7585
