Changes between Version 2 and Version 3 of FDORfc13
- 12/12/07 17:32:29 (17 years ago)
FDORfc13
v2 v3 31 31 http://portal.opengeospatial.org/files/?artifact_id=23206 32 32 33 We’ve started preparing for tile caching support in FDO. And we found that in most cases the G etMaprequest in current WMS protocol can be used for the tiling query. One exception is for the case where some stylization rules applied. For example, the following picture shows that duplicated labels are drawn when tiling is done.34 33 We’ve started preparing for tile caching support in FDO. And we found that in most cases the GETMAP request in current WMS protocol can be used for the tiling query. One exception is for the case where some stylization rules applied. For example, the following picture shows that duplicated labels are drawn when tiling is done. 34 35 35 To solve this problem, we’re intent to add a flag per WMS layer which indicates whether using tile cache or not. This way, user can set it up for different WMS layers, and can persist it in the FDO configuration. 36 36
