Changes between Version 6 and Version 7 of FDORfc16
03/18/08 19:43:29 (17 years ago)
traianstanev
  • TabularUnified FDORfc16
    v6 v7
    3333
    3434 * Data stored and consumed in native SQLite format, and therefore accessible to other SQLite-based applications;
    35  * Geometry will be serialized as BLOBs in FDO geometry format (FGF). Other ways that may be considered are storing points as X,Y columns and also geometry as WKB format;
     35 * Geometry will be serialized as BLOBs in FDO geometry format (FGF), WKB , or WKT 1.2 format. The type of geometry encoding will be specified in the geometry_columns table (see below) in a column called g_geometry_format. In addition, the provider may support point geometry with coordinates stored in non-geometric columns, via a connection string setting.
    3636 * A non-persistent, spatial index usable for BBOX queries built on the fly and valid for the duration of the FDO connection;
    3737 * Execution of arbitrary SQL commands;
    38  * A metadata table where the geometry coordinate system is stored in WKT or EPSG form. In addition, PRJ files will be supported as alternative means of specifying a coordinate system when a metadata table is undesirable;
     38 * Metadata about feature geometry and coordinate systems will be stored in OGC geometry_columns and spatial_ref_sys tables, according to Section 6.2.1 of the OGC Simple Feature spec, Part 2;
    3939 * A tentative list of supported FDO commands : !DescribeSchema, Select, !SelectAggregates, Insert, Update, Delete, !GetSpatialContexts, arbitrary SQL, !ApplySchema, !CreateDataStore;
    4040
