Changes between Version 2 and Version 3 of FDORfc21
- 05/22/08 08:45:46 (17 years ago)
FDORfc21
v2 v3 78 78 == Test Plan == 79 79 80 -Patches are ready to be provided against fdo-3.3.1 code and tested.81 -The new buildsystem can be introduced an commited in current trunk tree without affect any of current development and touching old files for now. 100% safe transition.80 * Patches are ready to be provided against fdo-3.3.1 code and tested. 81 * The new buildsystem can be introduced an commited in current trunk tree without affect any of current development and touching old files for now. 100% safe transition. 82 82 83 83 == Issues == 84 84 85 * Not all providers are converted. Is just manual work. Currently sdf, shp, postgis and gdal are done.85 * Not all providers are converted. Is just manual work. Currently sdf, shp, postgis and gdal are done. 86 86 * '''Question from Greg Boone:''' Are you proposing that all providers be converted before adopting such a system or only a subset? 87 87 * All providers, is a matter of a day to do the work. 88 88 89 * Still need to rely in private sources ( sqlite )90 * Not tested in many linux distros ( did on Mandriva, Suse and RH/Fedora )91 * Not tested in *nix ( did on !OpenSolaris build only )89 * Still need to rely in private sources ( sqlite ) 90 * Not tested in many linux distros ( did on Mandriva, Suse and RH/Fedora ) 91 * Not tested in *nix ( did on !OpenSolaris build only ) 92 92 93 93 == Funding/Resources == 94 94 95 == Questions from FDO Team == =95 == Questions from FDO Team == 96 96 97 97 * '''From Greg Boone:''' What source code changes are being proposed, if any ?
