Changes between Version 7 and Version 8 of FDORfc2
- 04/18/07 12:36:08 (18 years ago)
FDORfc2
v7 v8 174 174 This API change is applicable for all raster formats. For raster formats where the min/max cannot be deduced from the dataset, the provider should provide a mechanism to scan the image for min/max values if forced computation is requested. 175 175 176 This ECOis being written in order to better support ongoing development using the FDO Raster providers. Existing customers such as AutoCAD Map and !MapGuide have implemented work-arounds to calculate the scaling range manually.176 This RFC is being written in order to better support ongoing development using the FDO Raster providers. Existing customers such as AutoCAD Map and !MapGuide have implemented work-arounds to calculate the scaling range manually. 177 177 178 178 == Unresolved == 179 180 * It is questionable whether a method that can trigger a good deal of processing work belongs in a property oriented class like !FdoRasterDataModel.181 179 182 180 * When the raster data model bitsPerPixel is changed to 8, it is unclear how the provider is expected to convert the image to this number of bits per pixel. Should it scale using the min/max described here? Currently the FDO provider just truncates values outside the target pixel type range (as does the underlying GDAL RasterIO() API). … … 184 182 == Test Plan == 185 183 186 Raster Provider unit tests should be expanded to include usage of the new !MinMax Property184 Raster Provider unit tests should be expanded to include usage of the new !MinMaxValues Property 187 185 188 186 == Impact of Not Implementing this ECO ==
