Changes between Version 9 and Version 10 of FDORfc34
04/15/09 13:34:29 (16 years ago)
gregboone
  • FDORfc34
    v9 v10
    371371}}}
    372372
     373=== Interface IDataReader ===
     374
     375{{{
     376/// \brief
     377/// The FdoIDataReader interface provides a forward-only, read-only
     378/// iterator for reading relational table data. A reference to an
     379/// FdoIDataReader is returned from the SQLCommands ExecuteReader method.
     380/// The initial position of the FdoIDataReader interface is prior to the first item.
     381/// Thus, you must call ReadNext to begin accessing any data.
     382class FdoIDataReader: public FdoIReader
     383{
     384public:
     385...
     386...
     387...
     388    /// \brief
     389    /// Gets the data type of the property at the specified index position.
     390    ///
     391    /// \param index
     392    /// Input the index of the property.
     393    ///
     394    /// \return
     395    /// Returns the type of the property.
     396    ///
     397    FDO_API virtual FdoDataType GetDataType(FdoInt32 index);
     398
     399    /// \brief
     400    /// Gets the FDO property type of the property at the given index. This is used
     401    /// to indicate if a given property is a geometric property or a data property.
     402    /// If the property is a FdoPropertyType_DataProperty, then GetDataType
     403    /// can be used to to find the data type of the property.
     404    ///
     405    /// \param index
     406    /// Input the index of the property.
     407    ///
     408    /// \return
     409    /// Returns the FDO property type.
     410    ///
     411    FDO_API virtual FdoPropertyType GetPropertyType(FdoInt32 index);
     412};
     413}}}
     414
     415
    373416== Provider Implementation ==
    374417
