Changes between Version 7 and Version 8 of FDORfc37
06/11/09 19:27:19 (16 years ago)
leaf
  • FDORfc37
    v7 v8
    9797[[Image(ExceptionClasses.JPG, 782)]][[BR]]
    9898
    99     - !FdoNotConnectedException: The !FdoNotConnectedException class is the exception type thrown from classes in the Data package. This exception is thrown whenever executing an operation which requires FDO connection is connected, but FDO connection isn’t connected.
    100     - !FdoWrongConnectionParamValueException: The !FdoWrongConnectionParamValueException class is the exception type thrown from classes in the Connections package. This exception is thrown whenever connecting datastore with invalid connection parameters. The message should always mention which parameters were invalid.
     99    - !FdoDisconnectedException: The !FdoDisconnectedException class is the exception type thrown from classes in the Data package. This exception is thrown whenever executing an operation which requires FDO connection is connected, but FDO connection is disconnected.
     100    - !FdoInvalidConnectionParamValueException: The !FdoInvalidConnectionParamValueException class is the exception type thrown from classes in the Connections package. This exception is thrown whenever connecting datastore with invalid connection parameters. The message should always mention which parameters were invalid.
    101101    - !FdoInsufficentPrivilegesException: The !FdoInsufficentPrivliegesException class is the exception type thrown from classes in the Connections package. This exception is thrown whenever connecting a FDO data source without sufficient privileges.
    102102    - !FdoSQLCommandException: The !FdoSQLCommandException class is the exception type thrown from class FdoISQLCommand.
    105105    - !FdoNullPropertyValueException: The !FdoNullPropertyValueException class is the exception type thrown from classes editing property values of datastore. This exception is thrown whenever setting a non-nullable property value to null.
    106106    - !FdoOutOfRangePropertyValueException: The !FdoOutOfRangePropertyValueException class is the exception type thrown from classes editing property values of datastore. This exception is thrown whenever setting the property value to one which violates constraint !FdoPropertyValueConstraintRange.
    107     - !FdoNotUniquePropertyValueException: The !FdoNotUniquePropertyValueException class is the exception type thrown from classes editing property values of datastore. This exception is thrown whenever setting the property value to one which isn’t unique.
     107    - !FdoNonUniquePropertyValueException: The !FdoNonUniquePropertyValueException class is the exception type thrown from classes editing property values of datastore. This exception is thrown whenever setting the property value to one which isn’t unique.
    108108    - !FdoNotInListPropertyValueException: The !FdoNotInListPropertyValueException class is the exception type thrown from classes editing property values of datastore. This exception is thrown whenever setting the property value to one which violates constraint !FdoPropertyValueConstraintList.
    109109    - !FdoSchemaDoesNotExistException: The !FdoSchemaDoesNotExistException class is the exception type thrown from classes in the Data and Schema packages. This exception is thrown whenever the specified schema doesn’t exist.
