Changes between Version 4 and Version 5 of FDORfc47
- 01/13/10 10:13:11 (15 years ago)
FDORfc47
v4 v5 42 42 Managed API callers will experience some performance impact as outlined below. All clients will incur a larger memory allocation/overhead due to the addition of the Boolean variable. 43 43 44 NOTE: Timing tests were made to test the impact of implementing an Interlocked strategy vs using a Mutex. The testing involved repeatedly calling !AddRef and Release on a single unmanaged FDO object. 100 million repetitions ( 44 NOTE: Timing tests were made to test the impact of implementing an Interlocked strategy vs using a Mutex. The testing involved repeatedly calling !AddRef and Release on a single unmanaged FDO object. 100 million repetitions (100 million !AddRef and 100 million Release calls) were done using a release build. 3 different cases were tried: 45 45 46 46 * Unguarded !AddRef and Release (as is now)
