Changes between Version 5 and Version 6 of FDORfc4
- 04/19/07 10:41:23 (18 years ago)
FDORfc4
v5 v6 285 285 We are still working on finalizing the changes required to the Linux build scripts. 286 286 287 == Test Plan==287 === Test Plan === 288 288 289 289 The ArcSDE Provider unit tests will be run against development/runtime configurations where ArcSDE 9.1 or 9.2 or both are installed. … … 291 291 The ArcSDE Provider will be re-tested in AutoCAD Map 2008 and !MapGuide !OpenSource 1.2. 292 292 293 == Impact of Not Implementing this ECO==293 === Impact of Not Implementing this ECO === 294 294 295 295 If this RFC is not implemented, FDO clients will not be able to exercise the ArcSDE provider against the ArcSDE 9.2 client. 296 296 297 == Funding/Resources==297 === Funding/Resources === 298 298 299 299 Autodesk to provide resources / funding to update the ArcSDE provider.
