Changes between Version 14 and Version 15 of FDORfc60
04/13/11 09:06:47 (14 years ago)
gregboone
  • FDORfc60
    v14 v15
    400400}}}
    401401
     402==== Selecting Annotation Text Objects Through FDO ====
     403
     404Annotation Text instances owned by FDO features will be queryable and selectable through a new FDO Interface FdoIAnnotation. The FdoIAnnotation type will be considered a primary data type that can be accessed when reading FDO features, in the same manner that Raster, Association and Geometry are currently exposed. This will allow complex Annotation objects to be associated to logical features such as roads, pipes, etc.
     405
     406The FdoIAnnotation Interface allows clients that interact with and maintain Annotation text to do so through a single interface. Whereas the data that completely defines the set of Text Elements may be spread across several logical classes, accessing the Annotation will be managed through a more linear mechanism that allows users to manage data with worrying where that data is stored.
     407
     408{{{
     409class FdoIAnnotation : public FdoIDisposable
     410{
     411public:
     412    FdoIEnvelope* TextEnvelope;
     413    FdoString* DefaultBaseMapScale;
     414    FdoExpression* DefaultTextValue;
     415    FdoString* DefaultTextAttributesAsXml;
     416    FdoAnnotationTextElementCollection* TextElements;
     417};
     418}}}
     419
     420In this simplified view of FdoIAnnotation, we see how the Annotation’s text envelope, map scale, default values, and text elements are all available through a single interface.
     421
     422From FdoIAnnotation, users are able to retrieve the collection of text attributes associated to the annotation. This is possible by accessing the TextElements property and iterating over the returned !FdoAnnotationTextElement Collection. Each object in the collection represents a piece of individual Annotation text.
     423
     424{{{
     425class FdoAnnotationTextElement : public FdoIDisposable
     426{
     427public:
     428    FdoByteArray*  Location;
     429    FdoByteArray*  LeaderLine;
     430    FdoExpression* TextValue;
     431    FdoString*     TextAttributesAsXml;
     432};
     433}}}
     434
     435In order to access the above example data through the FDO logical model The FDO API’s !FdoFeatureReader class will be extended to allow Annotation properties to be queried by name and by index, in the same manner as Geometry and Raster properties are today queried.
     436
     437{{{
     438class FdoIFeatureReader: public FdoIReader
     439{
     440public:
     441
     442
     443    FdoIAnnotation* GetAnnotation(FdoString* propertyName);
     444    FdoIAnnotation* GetAnnotation(FdoInt32 index);
     445};
     446}}}
     447
     448
     449===== Querying Features with Annotation Properties =====
     450
     451Using the above Road/!RoadAnnotation Example, here is an example of how Annotation properties would be queried from an FDO data store.
     452
     453{{{
     454// Create a select command to retrieve Road features and its associated Annotations
     455FdoISelectP selectCmd = (FdoISelect*)conn->CreateCommand(FdoCommandType_Select);
     456selectCmd->SetFeatureClassName(L"Road");
     457
     458// Add the class properties to the selection set, including the Annotation property
     459FdoIdentifierCollectionP props =  selectCmd->GetPropertyNames();
     460props->Add(FdoIdentifierP(FdoIdentifier::Create(L"FeatId")));
     461props->Add(FdoIdentifierP(FdoIdentifier::Create(L"Geometry")));
     462props->Add(FdoIdentifierP(FdoIdentifier::Create(L"Name")));
     463props->Add(FdoIdentifierP(FdoIdentifier::Create(L"Width")));
     464props->Add(FdoIdentifierP(FdoIdentifier::Create(L"Annotation")));
     465
     466// The selection can be arbitrarily filtered against
     467FdoFilterP filter = FdoFilter::Parse(L"FeatId > 100");
     468selectCmd->SetFilter(filter);
     469
     470// Execute the command and get a feature reader that points to the retrieved records
     471FdoIFeatureReaderP reader = selectCmd->Execute();
     472while (reader->ReadNext())
     473{
     474    // Get the Annotation property by name
     475    FdoPtr<FdoIAnnotation> annotation = reader->GetAnnotation(L"Annotation");
     476
     477    // The annotation will have an envelope and default properties, some
     478    // or all of which may be NULL. Envelope is a Geometry ByteArray. The
     479    // Default Text will be an expression that can be evaluated as any
     480    // database value
     481    FdoByteArrayP envelope = annotation->GetEnvelope();
     482    FdoExpressionP defaultText = annotation->GetDefaultTextValue();
     483    FdoStringP defaultTextAttributes = annotation->GetDefaultTextAttibutesAsXml();
     484    const char* charArray = (const char*)textAttributes;
     485
     486    // The TextAttributes would be an XML string that needs to be streamed into memory
     487    // and then Read into the XML API class FdoTextElementAttributes
     488    FdoIoMemoryStreamP stream = FdoIoMemoryStream::Create();
     489    stream->Write( (FdoByte*) charArray, strlen(charArray) );
     490    stream->Reset();
     491
     492    // Create the XML API class that allows programatic access to the XML properties
     493    // and read the XML stream into the corresponding classes.
     494    FdoTextElementAttributesP defaultAttributes = FdoTextElementAttributes::Create();
     495    defaultAttributes->ReadXml(stream);
     496
     497    // Each Annotation has 0...n Text Elements that are the actual text values
     498    FdoAnnotationTextElementCollectionP textElements = annotation->GetTextElements();
     499    for (FdoInt32 i=0; i<textElements->GetCount(); i++)
     500    {
     501        // Get the nth Text Element and read its values
     502        FdoAnnotationTextElementP textElement = textElements->GetItem(i);
     503        FdoExpressionP textValue = textElement->GetTextValue();
     504        FdoByteArrayP location = textElement->GetLocation();
     505        FdoByteArrayP leader = textElement->GetLeaderLine();
     506
     507        // As seen above, the XML text will need to be parsed into its API clases
     508        FdoStringP textAttributes = textElement->GetTextAttributesAsXml();
     509        if (textAttributes != L"")
     510        {
     511            const char* charArrayA = (const char*)textAttributes;
     512            FdoIoMemoryStreamP streamA = FdoIoMemoryStream::Create();
     513            streamA->Write( (FdoByte*) charArrayA, strlen(charArrayA) );
     514            streamA->Reset();
     515
     516            FdoTextElementAttributesP attributes = FdoTextElementAttributes::Create();
     517            attributes->ReadXml(streamA);
     518        }
     519    }
     520}
     521}}}
     522
    402523
    403524
