Changes between Version 5 and Version 6 of FDORfc60
04/13/11 08:07:45 (14 years ago)
gregboone
  • FDORfc60
    v5 v6
    9494||A_TEXT_DEFAULT_EXPRESSION,[[BR]]A_TEXT_DEFAULT_ATTRIBUTES||The default values for the corresponding “A_TEXT_” columns above, for cases where these columns are NULL in the feature table. They may be values or “query” expressions in terms of other columns in the database. These defaults shall be overridden on a row by row basis when the corresponding columns in the feature table row are not NULL.||
    9595
    96 TBD
     96=== Integrating Annotation Text Concepts into the FDO API ===
     97
     98In order to support Annotation Text and the concepts outlined in the sections above, the object and metadata relationships defined by the OGC Simple Feature Access Specification will be incorporated into the FDO API as outlined in the sections below.
     100==== Annotation Text Definitions as an FDO Property Definition ====
     101
     102Annotation Text and its logical metadata will be creatable, modifiable and describable via the FDO API schema. Annotation Text will be defined as properties on FDO Feature Classes and be exposed in the same manner as Geometry, Raster and Associations, via an FDO property definition class that derives from !FdoPropertyDefinition. In this manner, class !FdoAnnotationPropertyDefinition will be added to the API and will contain the definition of the schema, classes and properties that define the location of the Annotation components. These elements are the logical properties that are needed to store the annotation text value, envelope, leader line, location and text attributes. The schema, classes and properties identified by these metadata properties will in turn be accessible through their own FDO schema definitions.
     103
     104===== Starting from an Existing Physical Schema =====
     105
     106Let us use the following physical schema as a starting point for further discussion.  In this example a Road table is used to capture the Location, Name and Width of road objects in a city. Associated to the Road table is a !RoadAnnotation table that contains textual labels that describe the road. A Road object can be associated to 0…n !RoadAnnotation objects.
     107
    97108
    98109
