Changes between Version 6 and Version 7 of FDORfcTemplate
03/22/11 19:23:27 (14 years ago)
sunch
  • FDORfcTemplate
    v6 v7
    88----
    9 = FDO RFC # - Title Goes Here =
     9= FDO RFC # - Support Proxy Server Settings for WMS/WFS =
    1010
    1111This page contains a request for comments document (RFC) for the FDO Open Source project.
    1414== Status ==
    1515
    16 ||RFC Template Version||(1.1)||
    17 ||Submission Date||(Date/Time submitted)||
    18 ||Last Modified||(your name - Month Day, Year)||
    19 ||Author||(your name here)||
    20 ||RFC Status||(draft, proposed, frozen for vote, adopted, retracted, or rejected)||
    21 ||Implementation Status||(pending, under development, completed)||
    22 ||Proposed Milestone||(e.g. 1.1, 1.3)||
    23 ||Assigned PSC guide(s)||(when determined)||
    24 ||'''Voting History'''||(vote date)||
    25 ||+1||Bob, Mateusz||
    26 ||+0||Frank||
    27 ||-0||Orest||
    28 ||-1||Greg (troublemaker)||
     16||RFC Template Version||1.1||
     17||Submission Date||March 23, 2011||
     18||Last Modified||Cheney Sun||
     19||Author||Cheney Sun||
     20||RFC Status||frozen for vote||
     21||Implementation Status||under development||
     22||Proposed Milestone||3.7.0.0 ||
     23||Assigned PSC guide(s)||Orest Halustchak, Greg Boone||
     24||'''Voting History'''||||
     25||+1||||
     26||+0||||
     27||-0||||
     28||-1||||
    2929
    3030== Overview ==
    3131
    32 This section briefly describes the problem set, and the proposed solution in general terms.  It should be deliberately short, a couple of sentences or so.
     32The RFC is to enhance the WMS/WFS provider to have the capabilities to set proxy parameters.
    3333
    3434== Motivation ==
    3535
    36 This is the most important part of the RFC.  It describes the problem domain in detail.  Focusing on this will allow reviewers to fully understand why the proposed change is being made, and potentially suggest different/better ways of accomplishing the desired results.  The more time we spend on understanding the problem, the better our solution will be.
     36As one feedback from FDO API and WMS/WFS provider users, a number of requests have arisen regarding access to Web Services, such as WMS and WFS, through a proxy server. A proxy server acts as an intermediary between an internal network (Intranet) and the Internet, transiting the remote data package to the internal client.
     37Currently, WMS/WFS FDO providers have a workaround to support proxy setting, which is provided by the libcurl library. It reads the proxy settings defined in the system variables. This is not good for the provider users, especially for the API users. The better way is to expose one entry in the provider to let user set the proxy information before opening a connection. This can be done by enhancing and expanding the connection parameter list that each provider supports. And then pass these values into OWS component. The OWS component will define proxy setting via libcurl API if the proxy values aren’t null.
     38Libcurl library has already proxy setting capability, so what we need to do is expose it via FDO API, and enhance the delegate classes for both WMS/WFS.
    3739
    3840== Proposed Solution ==
    3941
    40 This is a more detailed description of the actual changes desired.  The contents of this section will vary based on the target of the RFC, be it a technical change, website change, or process change.  For example, for a technical change, items such as files, XML schema changes, and API chances would be identified.  For a process change, the new process would be laid out in detail.  For a website change, the files affected would be listed.
     42The following tables outline the additional connection properties that will be introduced in order to allow proxy server access.
     43||'''Property'''        ||'''Value'''||
     44||Name||        ProxyServerName||
     45|| LocalizedName        ||ProxyServerName (English)||
     46|| DefaultValue ||||
     47|| IsRequired   || No||
     48|| IsProtected  || No||
     49|| IsEnumerable || No||
     50|| IsFileName   || No||
     51|| IsFilePath   || No||
     52|| IsDatastoreName||    No||
     53The ProxyServerName property specifies the name of a user specified proxy server that will be used to make the connection to the external web service. This could be a host name or an IP address.
     54||'''Property'''        ||'''Value'''||
     55||Name||        ProxyServerPort||
     56||LocalizedName ||ProxyServerPort(English)||
     57||DefaultValue  ||||
     58||IsRequired    || No||
     59||IsProtected   || No||
     60||IsEnumerable  || No||
     61||IsFileName    || No||
     62||IsFilePath    || No||
     63||IsDatastoreName||     No||
     64The ProxyServerPort property specifies the port of the user-specified proxy server that will be used to connect to the Internet. If set, it must be used in conjunction with the ProxyServerName parameter.
     65||'''Property'''        ||'''Value'''||
     66||Name||        ProxyServerUsername||
     67||LocalizedName ||ProxyServerUsername(English)||
     68||DefaultValue  ||||
     69||IsRequired    || No||
     70||IsProtected   || No||
     71||IsEnumerable  || No||
     72||IsFileName    || No||
     73||IsFilePath    || No||
     74||IsDatastoreName||     No||
     75The ProxyServerUsername property specifies the username to be used when connecting to a user-specified proxy server. If set, it must be used in conjunction with the ProxyServerName and ProxyServerPassword parameters.
     76||'''Property'''        ||'''Value'''||
     77||Name||        ProxyServerPassword||
     78||LocalizedName ||ProxyServerPassword(English)||
     79||DefaultValue  ||||
     80||IsRequired    || No||
     81||IsProtected   || No||
     82||IsEnumerable  || No||
     83||IsFileName    || No||
     84||IsFilePath    || No||
     85||IsDatastoreName||     No||
     86The ProxyServerPassword property specifies the password to be used when connecting to a user-specified proxy server. If set, it must be used in conjunction with the ProxyServerName and ProxyServerPassword parameters.
     87When user wants to use some proxy server for one provider, the proxy information should be set in the connection information before opening the remote WMS/WFS connection.
     88Accordingly, the relevant delegates in WMS and WFS should also be updated to enhance their constructors to accept the proxy settings.
     89
     90For FdoWmsDelegate class:
     91
     92{{{
     93class FdoWmsDelegate : public FdoOwsDelegate
     94{
     95......
     96/// \brief
     97/// Construct the FdoWmsDelegate instance with additional proxy information
     98FDOOWS_API FdoWmsDelegate (
     99                                FdoString* defaultUrl,
     100                                FdoString* userName,
     101                                FdoString* passwd,
     102                                FdoString* proxyUrl = NULL,
     103                                FdoString* proxyPort = NULL,
     104                                FdoString* proxyUsername = NULL
     105                           )
     106};
     107}}}
     108For FdoWfsDelegate class:
     109
     110{{{
     111class FdoWfsDelegate : public FdoOwsDelegate
     112{
     113......
     114/// \brief
     115/// Construct the FdoWfsDelegate instance with additional proxy information
     116FDOOWS_API FdoWfsDelegate (
     117                                FdoString* defaultUrl,
     118                                FdoString* userName,
     119                                FdoString* passwd,
     120                                FdoString* proxyUrl = NULL,
     121                                FdoString* proxyPort = NULL,
     122                                FdoString* proxyUsername = NULL
     123                           )
     124};
     125}}}
     126The proxyUrl, proxyPort, proxyUsername all have the NULL as their default value. Their parent constructor FdoOwsDelegate will be called to pass the proxy settings.
    41127
    42128== Implications ==
    43129
    44 This section allows discussion of the repercussions of the change, such as whether there will be any breakage in backwards compatibility, if documentation will need to be updated, etc.
     130•       Some new connection properties are introduced.[[BR]]
     131•       Both constructors of FdoWmsDelegate and FdoWfsDelegate class will be enhanced with more parameters.
     132
    45133
    46134== Test Plan ==
    47135
    48 How the proposed change will be tested, if applicable.  New unit tests should be detailed here???
     136Add unit tests into WMS/WFS provider to test the specified proxy setting.
    49137
    50138== !Funding/Resources ==
    51139
    52 This section will confirm that the proposed feature has enough support to proceed.  This would typically mean that the entity making the changes would put forward the RFC, but a non-developer could act as an RFC author if they are sure they have the funding to cover the change.
     140Autodesk to provide resources / funding
