Changes between Version 12 and Version 13 of FdoWmsNotes
02/17/08 17:53:21 (17 years ago)
amorsell
  • FdoWmsNotes
    v12 v13
    237237  <Parameter>
    238238    <Name>FeatureServer</Name>
    239     <Value>%WMSService% </Value>
     239    <Value>%WMSService%</Value>
    240240  </Parameter>
    241241  <ConfigurationDocument>config.xml</ConfigurationDocument>
    281281If Studio was running when you created the feature source you may have to refresh the site explorer to make it show up.
    282282
    283
    284
     283= Example =
     284Attached to this page are two XML files that demonstrate the Basic Configuration Document and resource document.  In the configuration document, NASA_WMS_config_doc.xml, we have chosen a %FeatureClassName% of NASAWMSGlobalPan.  In addition, the %LayerName% is global_mosaic as determined from http://wms.jpl.nasa.gov/wms.cgi?service=wms&request=GetCapabilities.  Then, in NASA_WMS_resource_doc.xml, we are using the NASA WMS server for the %WMSService% parameter.  From there, the resource document can be uploaded using the mapagent with a FeatureSource name of our choice, and then the configuration document applied to that resource.
     285
