Changes between Initial Version and Version 1 of TracBatchModify
04/22/15 15:13:21 (10 years ago)
  • TracBatchModify
     1= Trac Ticket Batch Modification =
     2[[TracGuideToc]]
     4Trac supports modifying a batch of tickets in one request from [TracQuery custom query] results .
     6To perform a batch modification, select the tickets you wish to modify and set the new field values using the section underneath the query results.
     8== List fields
     10The `Keywords` and `Cc` fields are treated as lists, where list items can be added and/or removed in addition of replacing the entire list value. All list field controls accept multiple items, such as multiple keywords or cc addresses.
     12== Excluded fields
     13
     14Multi-line text fields are not supported, because no valid use-case has been presented for syncing them across several tickets. That restriction applies to the `Description` field as well as to any [TracTicketsCustomFields#AvailableFieldTypesandOptions custom field] of type 'textarea'. However, Trac version 1.0 supports more suitable actions like 'prepend', 'append' or 'search & replace' ([http://trac-hacks.org/ticket/2415 th:#2415]).
