Changes between Initial Version and Version 1 of WikiRestructuredTextLinks
01/30/07 14:02:25 (18 years ago)
  • WikiRestructuredTextLinks
     1= TracLinks in reStructuredText =
     3This document illustrates how to use the ``..trac::`` directive in reStructureThe page is written like
     5{{{
     6{{{
     7#!rst
     8
     9Examples:
     10 * Tickets: :trac:`#1` or :trac:`ticket:1`
     11 * Ticket comments: :trac:`comment:ticket:1:2`
     12 * Reports: :trac:`{1}` or :trac:`report:1`
     13 * Changesets: :trac:`r1`, :trac:`[1]` or :trac:`changeset:1`
     14 * Revision log: :trac:`r1:3`, :trac:`[1:3]` or :trac:`log:@1:3`, :trac:`log:trunk@1:3`
     15 * Diffs (since version 0.10): :trac:`diff:@20:30`, :trac:`diff:tags/trac-0.9.2/wiki-default//tags/trac-0.9.3/wiki-default` or :trac:`diff:trunk/trac@3538//sandbox/vc-refactoring/trac@3539`
     16 * Wiki pages: :trac:`CamelCase` or :trac:`wiki:CamelCase`
     17 * Milestones: :trac:`milestone:1.0`
     18 * Attachment: :trac:`attachment:ticket:944:attachment.1073.diff`
     19 * Files: :trac:`source:trunk/COPYING`
     20 * A specific file revision: :trac:`source:/trunk/COPYING@200`
     21 * A particular line of a specific file revision: :trac:`source:/trunk/COPYING@200#L25`
     23}}}
     24}}}
     25
     26Provided you have docutils installed, the above block will render as:
     27----
     28{{{
     29#!rst
     30
     31Examples:
     32 * Tickets: :trac:`#1` or :trac:`ticket:1`
     33 * Ticket comments: :trac:`comment:ticket:1:2`
     34 * Reports: :trac:`{1}` or :trac:`report:1`
     35 * Changesets: :trac:`r1`, :trac:`[1]` or :trac:`changeset:1`
     36 * Revision log: :trac:`r1:3`, :trac:`[1:3]` or :trac:`log:@1:3`, :trac:`log:trunk@1:3`
     37 * Diffs (since version 0.10): :trac:`diff:@20:30`, :trac:`diff:tags/trac-0.9.2/wiki-default//tags/trac-0.9.3/wiki-default` or :trac:`diff:trunk/trac@3538//sandbox/vc-refactoring/trac@3539`
     38 * Wiki pages: :trac:`CamelCase` or :trac:`wiki:CamelCase`
     39 * Milestones: :trac:`milestone:1.0`
     40 * Attachment: :trac:`attachment:ticket:944:attachment.1073.diff`
     41 * Files: :trac:`source:trunk/COPYING`
     42 * A specific file revision: :trac:`source:/trunk/COPYING@200`
     43 * A particular line of a specific file revision: :trac:`source:/trunk/COPYING@200#L25`
     44
     45}}}
     46----
     47
     48Note also that any of the above could have been written using the alternate syntax for roles:
     49{{{
     50{{{
     51#!rst
     52
     53See `ticket:123`_
     54
     55 .. :trac: ticket:123 Ticket 123
     56}}}
     57}}}
     58----
     59
     60{{{
     61#!rst
     62
     63See _`ticket:123`
     64
     65.. trac:: ticket:123 Ticket 123
     66}}}
     67----
     68The above form has the additional benefit of allowing you to specify an explicit label for the link.
     69
     70----
     71See also: WikiRestructuredText, TracLinks
