Changes between Initial Version and Version 1 of Ticket #2
01/09/08 06:22:32 (17 years ago)
neteler
developers,
is there any known issue with flex-2.5.34?
  • Ticket #2
    • Property Cc grass-dev@… added
    • Property Component Docsdefault
  • Ticket #2 – Description
    initial v1
    1919So I cd to /usr/src/grass-6.2.3/lib/db/sqlp and run make which then gives;
    2020
     21{{{
    2122root@sidney /usr/src/grass-6.2.3/lib/db/sqlp # make
    2223flex lex.l
    2930lex.l:35: bad character: 0
    3031make: *** [lex.yy.c] Error 1
     32}}}
    3133
    3234The remaining directories /usr/src/grass-6.2.3/db/drivers/dbf, /usr/src/grass-6.2.3/db/drivers/postgres and /usr/src/grass-6.2.3/db/drivers/ogr fail on the make because it cannot find;
    3840The error shown for /usr/src/grass-6.2.3/lib/db/sqlp looks very similar to a recent problem I had with teTeX and flex-2.5.34. A small snip of that particular error looks like;
    3941
     42
     43{{{
    4044 gcc -DHAVE_CONFIG_H  -I. -I. -I../.. -I../.. -I.. -I./..  -O2 -march=athlon64 -pipe  -c y_tab.c -o y_tab.o
    4145    flex -l ./pl.l
    4549    ./pl.l:68: bad character: 4
    4650    ./pl.l:68: bad character: 0
    47
     51}}}
