Changes between Version 11 and Version 12 of AddOnsManagement
11/16/11 02:10:51 (13 years ago)
martinl
  • AddOnsManagement
    v11 v12
    2828}}}
    2929
    30 There is also available script called [source:grass-addons/tools/addons/compile-xml.sh compile-xml.sh] which compiles GRASS !AddOns modules for GRASS 6 and GRASS 7 and creates XML metadata file. This script simply calls `compile.sh` and `build-xml.py`. When running this script the main log files is stored to `~/grass<version>/addons/make.log` and each modules logs to `~/.grass<version>/addons/log/<module>.log`. Beside that the script also print basic information about progress to standard output
     30There is also available script called [source:grass-addons/tools/addons/compile-xml.sh compile-xml.sh] which compiles GRASS !AddOns modules for GRASS 6 and GRASS 7 and creates XML metadata file. This script simply calls `compile.sh` and `build-xml.py`. When running this script the main log files is stored in `~/grass<version>/addons/make.log` and each modules logs in `~/.grass<version>/addons/log/<module>.log`. Beside that the script also print basic information about progress to standard output
    3131
    3232{{{
