Changes between Version 11 and Version 12 of G8SourceLayout
- 02/17/21 12:47:59 (4 years ago)
G8SourceLayout
v11 v12 41 41 * `include` contains things for make, so any includes would go here? E.g., Jinja templates if we would have some or more realistic example `*.cmake` files. 42 42 * `include` does not contain grass, but the header files are there directly. Common source code layout nowadays is to have a directory named as the resulting directory in the distribution, i.e., not `include/*.h` but `include/grass/*.h`. This makes it easier for many code editing tools. 43 * PR:1350 43 44 * Python code in `lib/python` is next to C libraries which may look like it is a C library to communicate with Python. 44 45 * `lib/python` suffers from the same as header files in `include`. In this case it is even little more serious because it breaks rules on how a Python package should look like. Again, dir named `grass` should be inserted before the dir with the subpackages. 45 46 * https://github.com/OSGeo/grass/issues/1100 47 * PR:1356 46 48 * `gui/wxpython` again similar to `include` and `lib/python` because there is no "package" directory, but a greater reorganization may be needed as the "wxgui package" is not even in the distribution and the subdirectories are all top-level packages. 47 49
