| 151 | I added gradient function to 3D raster library and than added !r3.gradient module to addons. I tested it with and without OpenMP and it seems that OpenMP doesn't really speed up the module, it usually slows it down. So I will probably remove the OpenMP support completely. I also tried different settings of cache but again, I found no significant improvement with other than default settings. Then, I added more tests for !r3.flow (and found a bug) and !r3.gradient. In the gradient function, I added better handling for NULL values (after consulting with Soeren). Before, NULL values were ignored, now zero is set when one or more of the neighboring voxels are nulls. Null voxels are propagated. |
