| 16 | |
| 17 | '''Timeline''' |
| 18 | |||| timeline from proposal ||newly proposed timeline|| |
| 19 | ||MAY 1- 7 || "Early starts" Study ISO, INSPIRE and FGDC standards || |
| 20 | ||MAY 7 - 14 || Getting familiar with GRASS GIS modules code. || |
| 21 | ||MAY 14 - 19 || Design of metadata GRASS library|| design GRASS library (in Python) to read / write metadata based on ISO as flat XML files|| |
| 22 | ||MAY 19 || Starting GoSC x|| |
| 23 | ||MAY 19- 25 || Support of diferent metadata profiles ||design GRASS library (in Python) to read / write metadata based on ISO as flat XML files including profies (XSD validation, Inspire as the show-case)|| |
| 24 | ||MAY 26 - JUN 16 || "Break"(Prepare for bachelor final exam) ||add support for conversion GRASS (current) metadata files <-> XML ISO metadata || |
| 25 | ||JUN 16 - 24 || Implement basic library model for command line ||design cmd modules for reading and writing ISO-based metadata -> r.info.iso + v.info.iso (including support for conversion GRASS (current) metadata files <-> XML ISO metadata)|| |
| 26 | ||JUN 24 - 30 || Modules functionality (searching, publishing metadata)|| design GUI for reading and writing ISO-based metadata|| |
| 27 | ||JULY 1 - 7 || Design GUI|| design GUI for reading and writing ISO-based metadata -> g.gui.metadata|| |
| 28 | ||JULY 7 - 14 || Connect GUI library, basic functions|| Advanced metadata publishing/searching based on owslib + pycws|| |
| 29 | ||JULY 14 - 21 || Implementation of search function to GUI ||Advanced metadata publishing/searching based on owslib + pycws|| |
| 30 | ||JULY 21 - 30 || Improve metadata validation using designed GUI ||Advanced metadata publishing/searching based on owslib + pycws -> testing prototype|| |
| 31 | ||AUGUST 1 - 9 || Polishing code ||Polishing code|| |
| 32 | ||AUGUST 9 - 18 || Testing and documentation ||Testing and documentation|| |
| 33 | ||AUGUST 18 || The end of GSoC ||The end of GSoC|| |
