Changes between Version 74 and Version 75 of GSoC/2014/MetadataForGRASS
- 10/09/14 10:30:06 (10 years ago)
v74 v75 218 218 * Stored predefined metadata values in SQLite i.g.: keyword lists, points of contacts, and so on.[http://lists.osgeo.org/pipermail/grass-dev/2014-July/069872.html mailing list] 219 219 * to allow choosing topics from list(combobox) 220 * Export metadata to html->pdf220 * export metadata to html->pdf 221 221 * tooltips for toolbar 222 * renaming metadata according to renaming maps223 222 * renaming metadata according to renaming maps 224 223 * bug? http://thehacklist.blogspot.cz/2010/06/resolving-murrinestyledrawbox-assertion.html 225 224 * bug - gives empty space in the field of abstract 226 * renaming metadata according to renaming maps 225 * renaming metadata according to renaming maps in GRASS 226 * change BB to WGS84 by default 227 * The bounding box shall be expressed in decimal degree with a precision of at least 2 decimals 228 * The coordinates of the bounding box are expressed in any geodetic coordinate reference system with a Greenwich Prime Meridian 229 * to connect main validator with text inputs validation(email,number etc.) 230
