136 | | Test scripts must have module/package character (as unittests requires for test discovery). This applies true for unittests and doctests, no exceptions. Doctests (inside normal module code or in separate doc) will be wrapped as `unittest` test cases (in `testsuite` directory). There is a [https://docs.python.org/2/library/doctest.html#unittest-api standard way] to do it. To have the possibility of import, all the GRASS Python libraries shouldn't do anything fancy at import time. For example, doctests currently don't work with `grass.script` unless you call [source:grass/trunk/gui/wxpython/core/toolboxes.py?rev=60218#L630 a set of functions] to deal with function `_` because of installing translate function as buildin `_` function while `_` is used also in `doctest`. (This is fixed for GUI but still applies to Python libraries). |
137 | | |
| 136 | Test scripts must have module/package character (as unittests requires for test discovery). This applies for both unittests and doctests, no exceptions. To have the possibility of import, all the GRASS Python libraries shouldn't do anything fancy at import time. For example, doctests currently don't work with `grass.script` unless you call [source:grass/trunk/gui/wxpython/core/toolboxes.py?rev=60218#L630 a set of functions] to deal with function `_` (underscore) because of installing translate function as buildin `_` function while `_` function is used also in `doctest`. (This is fixed for GUI but still applies to Python libraries.) |
| 137 | |
| 138 | Doctests (inside normal module code, in separate documentation, or doctests created just for the purpose of testing, see [https://docs.python.org/2/library/doctest.html#soapbox explanation of different doctest use cases]) will be wrapped as `unittest` test cases (in the `testsuite` directory). There is a [https://docs.python.org/2/library/doctest.html#unittest-api standard way] to do it. Everything requires the possibility to import safely (without side effects). |
