Changes between Version 9 and Version 10 of GSoC/2018/IntegrationInQGIS3
06/12/18 06:00:33 (7 years ago)
radeknovotny94
Add 'Notes from discussions' and 'Future to do' section
  • GSoC/2018/IntegrationInQGIS3
    v9 v10
    304304(2) https://trac.osgeo.org/grass/wiki/GSoC/2018/IntegrationInQGIS3
    305305
    306 == Controversial decisions ==
     306== Notes from discussions ==
     307=== June 4: Hangout - Vaclav Petras, Radek Novotny ===
     308
     309=== How to parse questionable parameters? ===
     310
     311''' Raster 3D '''
     312
    307313If 'prompt' is 'raster_3d'
    308314        - if this parameter is required - delete description file for QGIS Processing, because Processing does not have 3D Raster class. Could be resolve later.
    318324r.to.rast3
    319325Need of 3D raster for module >>> r.to.rast3
    320 ----------------------------------------------------------------------------------
     326
     327''' Group input/output '''
     328
    321329If 'prompt' is 'group':
    322330        - only in module 'i.group' is parameter 'group' output
    324332                -if it is in 'r.' module, it is treated like raster multilayer
    325333                -if it is in 'v.' module, it is treated like vector multilayer
    326 ----------------------------------------------------------------------------------
    327 What is treating as the string in QGIS Processing:
    328
    329         - Separators - 'separator' and all names which have not equivalent class in Processing plugin - 'color', 'cats', 'dbname', 'dbtable'.
    330 ----------------------------------------------------------------------------------
     334
     335''' What is treating as the string in QGIS Processing: '''
     336
     337Separators - 'separator' and all names which have not equivalent class in Processing plugin - 'color', 'cats', 'dbname', 'dbtable'.
     338
     339''' GRASS layer, sublayer: '''
     340
    331341GRASS GIS layer and sublayer is passed because it is no equivalent in QGIS.
    332342
    333 === Splitting modules ===
    334
    335 r.slope.aspect in G vs r.slope, r.aspect, ... in Q
     343=== June 11: Hangout - Vaclav Petras, Martin Landa, Radek Novotny ===
     344=== How solve splitting modules in QGIS ===
     345
     346r.slope.aspect in GRASS GIS vs. r.slope, r.aspect, ... in QGIS Processing plugin
    336347
    337348Reasons for splitting:
    339350* Too many options
    340351
     352Conclusion: More intuitive distribution of parameters in GRASS GIS (more in Future to do)
     353
     354=== What is the best way how to divide parameters of modules in Processing plugin QGIS? ===
     355Discussed possibilities:
     356
     357- Required x Optional - This version was declined, because of a lot of important parameters are optional in GRASS modules.
     358
     359- Frequently used x Rarely used - This system was declined for now, because it is not clear what parameter is rarely or often used. But it could be a good point to think for future because this distribution has to be first done in GRASS GIS.
     360
     361- GUI Tabs - We decided for distribution according to the GUI sections in GRASS. It should be the least confusing system for users because it will be same in QGIS and GRASS. Also for future changes and maintenance, it appears like a good solution.
     362
     363=== How solved differences in GRASS and QGIS terminology. ===
     364
     365The biggest problem is that descriptions of parameters are different between GRASS and QGIS now and simultaneously parameter names are not shown in QGIS Processing plugin. So it is very difficult for a user to orientate in manuals.
     366
     367There are following variants:
     368- what is possible to change in GRASS, so change it. E.g. 'raster map' in GRASS x 'raster layer' in QGIS - could be solved as 'raster input' or 'raster output' without the word map or layer.
     369
     370- what is not possible change in GRASS, then add a new tag with OGC (or QGIS) friendly description. This description could be shown in manuals too.
     371
     372Because that's a big deal and have to be thoroughly discussed in GRASS Mailing list. I will try to find all differences in QGIS and GRASS terminology and report them to ML as a source for a final decision.
     373
     374== Future to do: ==
     375- add keywords to Processing Plugin - for improvement of searching in modules
     376- add similar keywords to ArcGIS tools to modules - for better orientation for ArcGIS users
     377- show parameters in Processing Plugin - for better orientation in GRASS manual for QGIS users.
     378- more intuitive distribution of parameters in GRASS - e.g. 'r.slope.aspect' could be divided into tabs slope and aspect, after this is not necessary to divide module in Processing Plugin to two modules - one for slope and second for aspect. Because it is intuitive to use just one tab if I want to compute slope.
     379
     380
     381
     382
     383
