Changes between Version 44 and Version 45 of GSoC/2020/StartupWindow
08/09/20 07:31:18 (4 years ago)
lindakladivova
  • GSoC/2020/StartupWindow
    v44 v45
    636636* Distinguish mapsets by ownership and lock in Data tab  (see https://github.com/OSGeo/grass/issues/714, https://github.com/OSGeo/grass/pull/849)
    637637
    638 Almost done, just some smaller cosmetic changes. In this PR I also established the mapset key "current". Therefore, not only locked mapset and mapset owned by a different owner than current user, but also current mapset is distinguished by label.
     638Almost done, just some smaller cosmetic changes. In this PR I also established the mapset key "current". Therefore, not only the locked mapset and the mapset owned by the different owner than the current user, but also the current mapset is distinguished by label.
    639639
    640640* Data Catalog: Double click on map from different locations fails - BUG (see https://github.com/OSGeo/grass/issues/884, https://github.com/OSGeo/grass/pull/886)
    641641
    642 The initial suggestion was to inform the user that the map is in the different location and ask if they want to switch to this mapset. However, there are probably more ways in the game on how to solve this issue (e.g. not allowing to display those maps at all?...) Should be discussed.
     642The initial suggestion was to inform the user that the map is in a different location and ask if they want to switch to this mapset. However, there are probably more ways in the game how to solve this issue (e.g. not allowing to display those maps at all?...) Should be discussed.
    643643
    644644'''2) What am I going to achieve for next week?'''\\
