Changes between Version 20 and Version 21 of GSoC/2021/JupyterAndGRASS
08/22/21 12:48:39 (4 years ago)
chaedri
  • GSoC/2021/JupyterAndGRASS
    v20 v21
    99|| GSoC proposal: || [https://docs.google.com/document/d/1ZT0cZobd87YCb3Ogis7RzWPj02XZkCpAHbC3VBGh7gc/edit?usp=sharing View Proposal]   ||
    1010
    11 [https://mybinder.org/v2/gh/OSGeo/grass/5e2fd30?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fjupyter_integration.ipynb Try grass.jupyter in Binder here]
     11[https://mybinder.org/v2/gh/OSGeo/grass/c173461?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fgrass_jupyter.ipynb Try grass.jupyter in Binder here]
    1212
    1313== Abstract ==
    14 The previous integration of GRASS GIS and Jupyter Notebooks required a cumbersome environment variable setup after launching GRASS from within the notebook. It also only allowed for simple, non-interactive map displays. The `grass.jupyter` subpackage for addresses both these issues by introducing a new startup function, `init()`, and two display classes, `GrassRenderer` and `InteractiveMap`. `GrassRenderer` renders GRASS displays as PNG images. `InteractiveMap` displays rasters and vectors in [https://python-visualization.github.io/folium/index.html folium], a leaflet library for Python.
     14The previous integration of GRASS GIS and Jupyter Notebooks required a cumbersome environment variable setup after launching GRASS from within the notebook and only allowed for simple, non-interactive map displays. The `grass.jupyter` subpackage for addresses both these issues by introducing a new startup function, `init()`, and two display classes, `GrassRenderer` and `InteractiveMap`. `GrassRenderer` renders GRASS displays as PNG images using a more intuitive syntax. `InteractiveMap` displays rasters and vectors interactively with [https://python-visualization.github.io/folium/index.html folium], a leaflet library for Python.
    1515
    1616== Goal ==
    432432
    433433**Abstract:**\\
    434 This project introduces a new subpackage for GRASS GIS, `grass.jupyter` that improves the integration of GRASS GIS with Jupyter Notebooks. Previously, using GRASS in Jupyter Notebooks required a cumbersome environment variable setup after launching GRASS from within the notebook. It also only allowed for simple, non-interactive map displays. The `grass.jupyter` subpackage for addresses both these issues by introducing a new startup function, `init()`, and two display classes, `GrassRenderer` and `InteractiveMap`. `GrassRenderer` renders GRASS displays as PNG images. `InteractiveMap` displays rasters and vectors in [https://python-visualization.github.io/folium/index.html folium], a leaflet library for Python.
     434This project introduces a new subpackage for GRASS GIS, `grass.jupyter` that improves the integration of GRASS GIS with Jupyter Notebooks. Previously, using GRASS in Jupyter Notebooks required a cumbersome environment variable setup after launching GRASS from within the notebook and only allowed for simple, non-interactive map displays. The `grass.jupyter` subpackage addresses both these issues by introducing a new startup function, `init()`, and two display classes, `GrassRenderer` and `InteractiveMap`. `GrassRenderer` renders GRASS displays as PNG images using an intuitive syntax. `InteractiveMap` displays rasters and vectors interactively with [https://python-visualization.github.io/folium/index.html folium], a leaflet library for Python.
    435435
    436436**The state of integration BEFORE the start of GSoC:**\\
    437 The previous integration of GRASS GIS and Jupyter Notebooks required a cumbersome environment variable setup after launching GRASS from within the notebook. There is an external python library grass_session that can be installed to shorten this launch substantially but, as an external library, it is not included in a typical GRASS install. Additionally, the previous integration allowed for maps to rendered as PNG images uses a unintuitive sequence of calling `d.erase`, then modules from the display family and finally rendering the image with IPython.display `Image()`.
     437The previous integration of GRASS GIS and Jupyter Notebooks required a cumbersome environment variable setup after launching GRASS from within the notebook. There is an external python library grass_session that can be installed to shorten this launch substantially but, as an external library, it is not included in a typical GRASS install. Additionally, the previous integration allowed for maps to rendered as PNG images uses a unintuitive sequence of calling `d.erase`, then modules from the display family and finally rendering the image with IPython.display `Image()`. For an example this workflow, see [https://mybinder.org/v2/gh/OSGeo/grass/c173461?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fbasic_example.ipynb basic_example.ipynb].
    438438
    439439**The state of integration AFTER GSoC:**\\
    440 With the help of my mentors, I introduced a new package `grass.jupyter` that contains a new `init()` function to shorten the launch and two display-related classes, `GrassRenderer` and `InteractiveMap`. `GrassRenderer` wraps the previous approach, rendering PNG images. Users create an instance of `GrassRenderer` then add elements to the rendering with GRASS display modules. The GRASS modules are called by using the name of module as a class method and replacing "." with "_" in the name. For example, to add a raster, one would call `GrassRenderer.d_rast(map="raster_name")`.
     440With the help of my mentors, I introduced a new package `grass.jupyter` that contains a new `init()` function to shorten the launch and two display-related classes, `GrassRenderer` and `InteractiveMap`. `GrassRenderer` wraps the previous approach, rendering PNG images but with a more intuitive syntax. Users create an instance of `GrassRenderer` then add elements to the rendering with GRASS display modules. The GRASS modules are called by using the name of module as a class method and replacing "." with "_" in the name. For example, to add a raster, one would call `GrassRenderer.d_rast(map="raster_name")`.
    441441
    442442`InteractiveMap`, the other display-related class in `grass.jupyter`, allows users to view GRASS vectors and rasters in [https://python-visualization.github.io/folium/index.html folium], a leaflet library for Python. After creating an instance of `InteractiveMap`, users can add vectors and rasters with `add_vector()` and `add_raster()`. Users can also add a layer control element with `add_layer_control()`. Folium only supports EPSG 4326 (for raster overlay) and EPSG 3857 (for vectors and coordinates) so `InteractiveMap` creates a temporary location, reprojects data then saves it to a temporary directory where it is imported by folium.
    4514513. introducing an interactive map display function (`InteractiveMap()`)
    452452
    453 The work I accomplished this summer paves the way for many future improvements, listed below in the Future Work section. In addition to some smaller modifications to `init()` and 'GrassRenderer', there remains a lot of work to be done on `InteractiveMap` or with other folium-GRASS classes/functions to fully access folium. I am grateful for the support I've received this summer and for the opportunity to contribute to GRASS GIS. I'm looking forward to continuing to improve `grass.jupyter`.
     453The work I accomplished this summer paves the way for many future improvements, listed below in the Future Work section. In addition to some smaller modifications to `init()` and 'GrassRenderer', there remains a lot of work to be done on `InteractiveMap` or with other folium-GRASS class to fully access folium. I am grateful for the support I've received this summer and for the opportunity to contribute to GRASS GIS. I'm looking forward to continuing to improve `grass.jupyter`.
    454454
    455455**Future Work:**\\
    492492
    493493Binder Examples: \\
    494 [https://mybinder.org/v2/gh/OSGeo/grass/5e2fd30?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fjupyter_integration.ipynb grass.jupyter tutorial]
    495 [more links coming...]
    496
    497
    498
     494[https://mybinder.org/v2/gh/OSGeo/grass/c173461?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fgrass_jupyter.ipynb grass_jupyter.ipynb]
     495[https://mybinder.org/v2/gh/OSGeo/grass/c173461?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fbasic_example_grass_jupyter.ipynb basic_example_grass_jupyter.ipynb]
     496[https://mybinder.org/v2/gh/OSGeo/grass/c173461?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fhydrology.ipynb hydrology.ipynb]
     497[https://mybinder.org/v2/gh/OSGeo/grass/c173461?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fviewshed_analysis.ipynb viewshed_analysis.ipynb]
     498[https://mybinder.org/v2/gh/OSGeo/grass/c173461?urlpath=lab%2Ftree%2Fdoc%2Fnotebooks%2Fsolar_potential.ipynb solar_potential.ipynb]
     499
     500
     501
