Changes between Version 85 and Version 86 of GSoC/2021/SingleWindowLayout
- 08/18/21 06:03:03 (3 years ago)
v85 v86 138 138 {{{#!td 139 139 '''wxGUI refactoring:''' 140 - Build all other Map Frames based wx.!Status bar (see PR https://github.com/OSGeo/grass/pull/1689)140 - Build all other Map Frames based wx.!StatusBar (see PR https://github.com/OSGeo/grass/pull/1689) 141 141 - Utilize Map Display panel into Map Display frame (see PR https://github.com/OSGeo/grass/pull/1675) 142 142 }}} … … 157 157 {{{#!td 158 158 '''wxGUI refactoring:''' 159 - Build all other Map Frames based !wx.Statusbar (see PR https://github.com/OSGeo/grass/pull/1689)159 - Build all other Map Frames based wx.!StatusBar (see PR https://github.com/OSGeo/grass/pull/1689) 160 160 - Utilize Map Display panel into Map Display frame (see PR https://github.com/OSGeo/grass/pull/1675) 161 161 }}} … … 176 176 {{{#!td 177 177 '''wxGUI refactoring:''' 178 - Build all other Map Frames based !wx.Statusbar (see PR https://github.com/OSGeo/grass/pull/1689)178 - Build all other Map Frames based wx.!StatusBar (see PR https://github.com/OSGeo/grass/pull/1689) 179 179 - Utilize Map Display panel into Map Display frame (see PR https://github.com/OSGeo/grass/pull/1675) 180 180 … … 209 209 {{{#!td 210 210 '''wxGUI refactoring:''' 211 - Build all other Map Frames based !wx.Statusbar (see https://github.com/OSGeo/grass/pull/1689)211 - Build all other Map Frames based wx.!StatusBar (see https://github.com/OSGeo/grass/pull/1689) 212 212 - Utilize Map Display panel into Map Display frame (see https://github.com/OSGeo/grass/pull/1675) 213 213 … … 234 234 {{{#!td 235 235 '''wxGUI refactoring:''' 236 - Build all other Map Frames based !wx.Statusbar (see https://github.com/OSGeo/grass/pull/1689)236 - Build all other Map Frames based wx.!StatusBar (see https://github.com/OSGeo/grass/pull/1689) 237 237 - Utilize Map Display panel into Map Display frame (see https://github.com/OSGeo/grass/pull/1675) 238 238 … … 400 400 Similarly as the last week, I focused on the GUI refactoring. I worked on the main refactoring PR (see https://github.com/OSGeo/grass/pull/1675). In terms of the main Map Display I am done here. However, me and my mentors realized that changes influence also other Map Frames - particularly g.gui.rdigit, d.mon, Map Swipe, Ground Control Point and IClass frame. 401 401 402 There were two possible ways how to proceed. First, I started with the statusbars for all the frames that we need newly to be created based on wx. Statubar widget (see https://github.com/OSGeo/grass/pull/1689). Then we came up with another concept, namely delegating methods using metaprogramming. Although this path seemed cheap at first (we talked about it very intensively on videocall on Wednesday), after a few hours of studying, we came to the conclusion that it is inappropriate in our case. And this decision subsequently opened PR https://github.com/OSGeo/grass/pull/1689 again.402 There were two possible ways how to proceed. First, I started with the statusbars for all the frames that we need newly to be created based on wx.!StatusBar widget (see https://github.com/OSGeo/grass/pull/1689). Then we came up with another concept, namely delegating methods using metaprogramming. Although this path seemed cheap at first (we talked about it very intensively on videocall on Wednesday), after a few hours of studying, we came to the conclusion that it is inappropriate in our case. And this decision subsequently opened PR https://github.com/OSGeo/grass/pull/1689 again. 403 403 404 404 Meantime, I also discovered the bug related to hiding statusbar and toolbars. Hiding does not work properly for above-mentioned map frames as e.g. Map Swipe. I set up the issue https://github.com/OSGeo/grass/issues/1691.
