Changes between Version 91 and Version 92 of Grass7/NewFeatures74
02/01/18 14:32:45 (7 years ago)
neteler
fix G7 macro to G74
  • Grass7/NewFeatures74
    v91 v92
    3535
    3636|| [[Image(wiki:Grass7/NewFeatures74:g.gui.image2target.png, align=center, 400px)]] || [[Image(wiki:Grass7/NewFeatures74:mapswipe.png, align=center, 400px)]]
    37 || ''G7:g.gui.image2target'' || ''Georectified photo''
     37|| ''G74:g.gui.image2target'' || ''Georectified photo''
    3838
    3939== Modules (commands) ==
    4949A new module, G74:r.geomorphon, to calculate geomorphons (terrain forms) and associated geometry using machine vision approach has been integrated (moved from Add-ons) into the core functionalities of GRASS GIS. A very nice addition to G74:r.out.gdal is the **possibility to create overviews** which enhances the compatibility with other GIS software packages.
    5050
    51 G7:r.in.gdal and G7:r.external provide support for import of raster maps exceeding 90N or 90S or with an EW extent larger than 360 degrees. Moreover, for imported lat-lon maps created with GIS software that uses limited floating point precision (common problem), an automatic fix of floating point precision errors in the grid geometry was implemented. Furthermore, G74:r.in.gdal and G74:r.import allow to **optionally limit the import map to the current region** (through -r flag and extent=region, respectively).
     51G74:r.in.gdal and G74:r.external provide support for import of raster maps exceeding 90N or 90S or with an EW extent larger than 360 degrees. Moreover, for imported lat-lon maps created with GIS software that uses limited floating point precision (common problem), an automatic fix of floating point precision errors in the grid geometry was implemented. Furthermore, G74:r.in.gdal and G74:r.import allow to **optionally limit the import map to the current region** (through -r flag and extent=region, respectively).
    5252
    5353Several other raster modules have been improved with new options, flags or parallelization support:
