Changes between Version 31 and Version 32 of Grass7/NewFeatures76
01/20/19 07:54:25 (6 years ago)
veroandreo
wip4
  • Grass7/NewFeatures76
    v31 v32
    1414
    1515 * See list here:
    16    * [wiki:Release/7.6.0-News] ~~(XXX 2019)~~ (7.6.0 forthcoming)
     16   * [wiki:Release/7.6.0-News] ~~(Jan 2019)~~ (7.6.0 forthcoming)
    1717 * The release development was officially moved to a dedicated release branch on Aug 31, 2018 (r73210).
    1818
    5555=== Vector modules ===
    5656
    57 The already impressive list of vector functions in GRASS GIS now includes ~~two~~ new modules that
     57Several vector modules have been significantly improved with new options, flags, fixes and other enhancements. Here are the most significant ones:
     58 * G7:v.proj comes now with a new pipeline option for high-accuracy re-projection
     59 * G7:v.in.ogr now also converts !OpenStreetMap line topology to GRASS topology, inserting nodes where appropriate (further details can be found in this dedicated wiki page [https://grasswiki.osgeo.org/wiki/OpenStreetMap#OSM_vs._GRASS_topology OSM vs GRASS topology])
     60 * G7:v.extract can now dissolve areas not only by category number, but also by attributes, while preserving category values and attribute tables. This is a significant improvement over G76:v.dissolve
     61 * G7:v.what.rast now supports to collect statistics from multiple input raster maps, instead of only one
     62 * G76:v.overlay has been improved in speedup for large and complex input areas
     63 * G76:v.rast.stats now also reports the number of NULL cells and it has a new where option, too
     64 * G76:v.to.rast now also supports centroids convertion
     65 * It is now possible to build squared buffers around points when -s flag is set
    5866
    59 Several other vector modules have been significantly improved with new options, flags, fixes and other enhancements:
    60  * G7:v.proj: new pipeline option for high-accuracy reprojection
    61  * G7:v.extract: it can now dissolve areas not only by category number, but also by attributes, at the same time preserving category values and attribute tables. This is an improvement over v.dissolve
    62  * G7:v.in.ogr: now also converts !OpenStreetMap line topology to GRASS topology, inserting nodes where appropriate ([https://grasswiki.osgeo.org/wiki/OpenStreetMap#OSM_vs._GRASS_topology OSM vs GRASS topology])
    63  * G7:v.what.rast: now supports to collect statistics from multiple input raster maps.
    64  * G76:v.overlay: speedup for large and complex input areas
    65  * G76:v.rast.stats: add number of NULL cells to method option, check for existence of attribute table before launching G76:v.to.rast, add where option, fix #3523
    66  * G76:v.to.rast: add support for centroids
    67  * G76:v.buffer: use squared buffers around points when -s flag is set
     67[screenshot here]
    6868
    6969=== Imagery modules ===
