Changes between Version 179 and Version 180 of Grass7Planning
- 09/28/15 03:12:41 (9 years ago)
Grass7Planning
v179 v180 45 45 * r65634 (wxGUI source code compatibility) 46 46 * r65774, r66129 - remove 'display map' tool 47 * r65519 temporal library: Store the default database connection as shell variable substitude to avoid wrong temporal database path's in cases the location was renamed or the path to the grass database changed.47 * ~~~r65519 temporal library: Store the default database connection as shell variable substitude to avoid wrong temporal database path's in cases the location was renamed or the path to the grass database changed.~~~ - done in r66366 48 48 * apply patch in #2688: get_np_array() calls grass.script.array without importing the module 49 49 == Blockers ==
