Changes between Version 362 and Version 363 of Grass7Planning
09/16/17 06:31:26 (7 years ago)
neteler
  • Grass7Planning
    v362 v363
    3939* vector modules: Added layer specific database information to v.info extended metadata flag: r69535
    4040* i18N: Install gettext to Python script modules to use translated strings extracted by r70817: r70818
    41 * ~v.what.strds: add capabilities to use names also for temporal dataset with minutes and seconds granularity: r69331~
    42 * ~~v.in.lidar: r70134~~ (done)
    43 * ~~d.linegraph: a series of improvements, see https://trac.osgeo.org/grass/log/grass/trunk/display/d.linegraph/main.c~~ (wenzeslaus: most are improvements/features, a lot of code changed, leaving it for 7.4)
    44 * ~~i.atcorr: Sentinel-2A r70161 (Test feedback in ML needed first)~~
    4541* r.grow.distance: clean up after r68611: r69327
    46 * ~~r.in.lidar: Storage type~~ (wenzeslaus: not sure what it is, but code is not identical in 7.2 and trunk)
    47 * ~~r.in.xyz: unify keywords and method descriptions with r.in.lidar (r68596): r68600~~ (done in r71300 and r70291)
    4842* lib/python/temporal: major differences to be checked TODO
    4943* r.in.srtm: Print an error instead of failing in a XY location: r70819
    5044
     45postponed:
     46* ~~d.linegraph: a series of improvements, see https://trac.osgeo.org/grass/log/grass/trunk/display/d.linegraph/main.c~~ (wenzeslaus: most are improvements/features, a lot of code changed, leaving it for 7.4)
     47* ~~i.atcorr: Sentinel-2A r70161 (Test feedback in ML needed first, leaving it for 7.4)~~
     48* ~~r.in.lidar: Storage type~~ (wenzeslaus: not sure what it is, but code is not identical in 7.2 and trunk, leaving it for 7.4)
     49* ~~v.what.strds: add capabilities to use names also for temporal dataset with minutes and seconds granularity: r69331 (leaving it for 7.4)~~
    5150== Blockers ==
    5251
