| 27 | |
| 28 | For example, to compare devbr6 and relbr64 using `kdiff3`: |
| 29 | ''(I used the QT version of Kdiff3)'' |
| 30 | {{{ |
| 31 | cd grass/svn/ |
| 32 | svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4 relbr64 |
| 33 | svn checkout https://svn.osgeo.org/grass/grass/branches/develbranch_6 devbr6 |
| 34 | |
| 35 | kdiff3 relbr64/ devbr6/ |
| 36 | }}} |
| 37 | |
| 38 | * This will take a little while to scan the two directory trees |
| 39 | * Once loaded, go to `Settings` → `Configure KDiff3...` |
| 40 | * Go into the Directory tab |
| 41 | * To "File-anti-pattern(s):" add "`;*.tmp.html`" |
| 42 | * To "Dir-anti-pattern(s):" add "`;OBJ.x86*;dist.x86*;bin.x86*`" |
| 43 | * ''(if not working with translations today you might add "`;locale`" to that too)'' |
| 44 | * In "File Comparison Mode" select "`Full analysis`" |
| 45 | * Go to the Diff tab |
| 46 | * In the "Line-matching preprocessor command:" line add "`grep -v "Last changed: $Date: 2"`" |
| 47 | * ''(this will ignore the $Date:$ svn keywords at the end of the help pages)'' |
| 48 | This is typically done by going into the options and telling it to ignore a list of wildcard'ed path names, and regex filter for the document content. |
