Changes between Version 3 and Version 4 of Python3Support
08/10/18 14:29:01 (7 years ago)
sanjeet
Added sections for pyp3 compatibilty code
  • Python3Support
    v3 v4
    8686>>> # in other words, user needs to know and specify the key as bytes
    8787}}}
     88
     89== Python 2 and Python 3 differences
     90The most important change between these two versions is dealing with strings.
     91* In Python 2:
     92 * Bytes == Strings
     93 * Unicodes != Strings
     94* In Python 3:
     95 * Bytes != Strings
     96 * Unicodes == Strings
     97
     98For Python 3, bytes objects can not contain character literals other than ASCII, therefore, we use bytes() to convert from unicode/string to byte object.
     99{{{
     100>>> bytes('Příšerný kůň', encoding='utf-8')
     101b'P\xc5\x99\xc3\xad\xc5\xa1ern\xc3\xbd k\xc5\xaf\xc5\x88'
     102}}}
     103To decode, use decode():
     104{{{
     105>>>b'P\xc5\x99\xc3\xad\xc5\xa1ern\xc3\xbd k\xc5\xaf\xc5\x88'.decode()
     106'Příšerný kůň'
     107}}}
     108We already have encode and decode functions available in (from grass.script.utils import encode, decode) lib/python/script/utils.py that makes it easy for us to convert back and forth. To make it work with Python3, made changes in those functions to avoid syntax errors and exceptions.
     109
     110
     111== How to write Python 3 compatible code
     112To check which Python version is being used, use sys.verson_info like:
     113{{{
     114import sys
     115if sys.version_info.major >= 3:
     116    //…
     117else:
     118    //...
     119}}}
     120
     121=== Other recommendations:
     122Use .format specifier for the strings and parameters.
     123For example instead of using:
     124{{{
     125'%s %s' % ('one', 'two')
     126}}}
     127Use:
     128{{{
     129'{} {}'.format('one', 'two')
     130}}}
     131.format is compatible with both Python 2 and Python 3.
     132
     133Read more at:
     134https://pyformat.info/
     135
     136
     137== wxPython GUI
     138There are a lot of changes found in wxPython Phoenix version. It is recommended to follow the MIgration guide (https://docs.wxpython.org/MigrationGuide.html) to properly migrate from the Classic version of wxPython. To support both the versions. The wrap.py includes a lot of new classes that work as a wrapper to accommodate both the versions of wxPython and Python itself.
     139
     140All the changes for Classic vs Phoenix can be found here:
     141https://wxpython.org/Phoenix/docs/html/classic_vs_phoenix.html
     142
     143We have created a wrap.py class that contains overloaded classes for wx classes to support both versions.
     144Example:
     145{{{
     146from gui_core.wrap TextCtrl, StaticText
     147}}}
     148Deprecated warnings can be removed by appropriately using the wx classes. Refer to the changes in both versions and see if the wrapper class is already created for the wx class; if not, create a new class in a similar manner as other wrapper classes in the wrap.py file.
     149
     150cmp function is not available in Python3, it has been custom created and included in gui/wxpython/core/utils.py file. Be sure to include it where cmp() is used.
     151
     152== References
