42 | | * G7:g.extension: improve handling of broken zip files on Windows |
43 | | * G7:g.manual: use web browser package |
44 | | * G7:g.mapset: added G_OPT_M_DIR for GISDBASE selection |
45 | | * G7:r.compress: print flag added; examples added |
46 | | * G7:r.mapcalc: prevent concurrent raster reads when a MASK is present |
47 | | * G7:r.report: fix broken layout (units moved to right) |
48 | | * G7:r.surf.idw: exit with fatal error in case of FCELL or DCELL input |
49 | | * G7:v.category: fix option=transfer, #2618 |
50 | | * G7:v.colors: reading from stdin is not supported, inform user about that |
51 | | * G7:v.in.ogr: do not use old projection for area calculations in new projection, improve topological cleaning suggestions |
52 | | * G7:v.surf.bspline: fix when no default DB is defined |
53 | | * G7:v.surf.rst: sync elevation color table with the new elevation table |
54 | | * G7:v.to.3d: make reverse transformation possible also for lines - contours |
55 | | * G7:v.vect.stats: fixed error msgs; examples added |
56 | | * G7:v.vol.rst: do not ignore null values in cross_input (causes serious slow down on MS Windows) |
57 | | * G7:v.what.strds: added |
| 44 | * G70:g.extension: improve handling of broken zip files on Windows |
| 45 | * G70:g.manual: use web browser package |
| 46 | * G70:g.mapset: added G_OPT_M_DIR for GISDBASE selection |
| 47 | * G70:r.compress: print flag added; examples added |
| 48 | * G70:r.mapcalc: prevent concurrent raster reads when a MASK is present |
| 49 | * G70:r.report: fix broken layout (units moved to right) |
| 50 | * G70:r.surf.idw: exit with fatal error in case of FCELL or DCELL input |
| 51 | * G70:v.category: fix option=transfer, #2618 |
| 52 | * G70:v.colors: reading from stdin is not supported, inform user about that |
| 53 | * G70:v.in.ogr: do not use old projection for area calculations in new projection, improve topological cleaning suggestions |
| 54 | * G70:v.surf.bspline: fix when no default DB is defined |
| 55 | * G70:v.surf.rst: sync elevation color table with the new elevation table |
| 56 | * G70:v.to.3d: make reverse transformation possible also for lines - contours |
| 57 | * G70:v.vect.stats: fixed error msgs; examples added |
| 58 | * G70:v.vol.rst: do not ignore null values in cross_input (causes serious slow down on MS Windows) |
| 59 | * G70:v.what.strds: added |
119 | | * G7:d.legend manual: example + screenshot added |
120 | | * G7:d.rast.num manual: example + screenshot added |
121 | | * G7:d.vect.chart manual: screenshot added |
122 | | * G7:g.gui.vdigit manual: added a paragraph on topological digitizing of polygons (+ some language corrections) |
123 | | * G7:g.mapsets manual: screenshot added for g.mapsets GUI; text improvements; HTML cosmetics |
124 | | * G7:i.eb.soilheatflux manual: more explanations about overpass time maps |
| 121 | * G70:d.legend manual: example + screenshot added |
| 122 | * G70:d.rast.num manual: example + screenshot added |
| 123 | * G70:d.vect.chart manual: screenshot added |
| 124 | * G70:g.gui.vdigit manual: added a paragraph on topological digitizing of polygons (+ some language corrections) |
| 125 | * G70:g.mapsets manual: screenshot added for g.mapsets GUI; text improvements; HTML cosmetics |
| 126 | * G70:i.eb.soilheatflux manual: more explanations about overpass time maps |
126 | | * G7:r.flow manual: examples added |
127 | | * G7:r.random.cells manual: clarify presence of 0 |
128 | | * G7:r.relief manual: added 'Exporting shaded relief maps to GeoTIFF' example |
129 | | * G7:r.slope.aspect manual: examples added |
130 | | * G7:r.watershed manual: clarify low mem max amount of pixels |
131 | | * G7:v.vect.stats added to G7:vectorintro.html |
132 | | * G7:v.vol.rst manual: wmult -> wscale; zmult -> zscale |
133 | | * G7:wxGUI vdigit manual: expanded |
| 128 | * G70:r.flow manual: examples added |
| 129 | * G70:r.random.cells manual: clarify presence of 0 |
| 130 | * G70:r.relief manual: added 'Exporting shaded relief maps to GeoTIFF' example |
| 131 | * G70:r.slope.aspect manual: examples added |
| 132 | * G70:r.watershed manual: clarify low mem max amount of pixels |
| 133 | * G70:v.vect.stats added to G70:vectorintro.html |
| 134 | * G70:v.vol.rst manual: wmult -> wscale; zmult -> zscale |
| 135 | * G70:wxGUI vdigit manual: expanded |
