Changes between Version 3 and Version 4 of Release/7.4.2-News
09/28/18 01:05:48 (6 years ago)
martinl
news updated
  • Release/7.4.2-News
    v3 v4
    3232(see also below for closed bugs)
    3333
     34* i.colors.enhance: check for not existing maps, see #2984
     35* i.vi: add NDVI keyword
     36* r.import: remove hardcoded memory limit
     37* i.segment: input bands must not be NULL or constant
     38* i.segment: avoid integer overflow with extremely large regions
     39* i.segment: fix memory management estimation
     40* v.to.db: add more keywords
     41* r.horizon: check if coordinates are within the current region, fixes #3634
     42
    3443==== Improvements in the Graphical User Interface ====
    3544
     45* Command prompt - Log files produces empty log files, closes #3657
     46* attribute table manager fails to start from new mapset, closes #3658
     47* wxGUI: wx4 doesn't have Image.GetHandlers, fixes #3617
     48
    3649==== Scripting ====
     50
     51* pygrass wrongly reports lines for point vector maps, closes #3549
     52* libpython: by default, no error output is produced even though the output in case of failure
    3753
    3854==== Projection support ====
    4056==== Library changes ====
    4157
     58
     59
    4260==== User Manuals - Documentation ====
    4361
     62* r.in.gdal manual: Raster Attribute Tables note added
     63* v.univar manual: beautify example section
     64* v.category: explain option=report
     65* r.fillnulls manual: example extended with bilinear method
     66* v.surf.rst manual: example changed from Spearfish to North Carolina dataset
     67* d.vect: explain z height for 3D lines/polygons, see #934
     68* i.atcorr: update manual for PlanetScope 0f
     69
    4470==== Portability ====
     71
     72* Dockerfile: have UTF8 defined
     73* Dockerfile: 'set ENV SHELL' to avoid /bin/sh fallback in interactive GRASS GIS sessions in docker
     74* wingrass: wxpython packages rename to python-wx
     75* winGRASS: add python-ply as a dependency
     76* winGRASS: add pip as dependency
    4577
    4678==== Message Translations ====
