Changes between Version 1 and Version 2 of Release/7.6.2-News
08/18/19 08:40:33 (6 years ago)
neteler
  • Release/7.6.2-News
    v1 v2
    5454
    5555 * G76:r.buildvrt: manual cosmetics
    56  * G76:r.compress: print which compression method is actually applied; update documentation with regard to ZSTD as default compression if available, see #3758
     56 * G76:r.compress: print which compression method is actually applied; update documentation with regard to ZSTD compression if available, see #3758, #3815
    5757 * G76:r.kappa: Pass correct map@mapset combo to the r.stats call
    5858 * G76:v.in.ogr: set spatial filter to correct geometry field if geometry option is given
