Changes between Version 17 and Version 18 of Submitting/Docs
09/19/16 00:52:54 (8 years ago)
sbl
add link to HTML validator
  • Submitting/Docs
    v17 v18
    1919
    2020Important: The HTML file contains '''no header nor footer'''. The complete HTML file is autogenerated during the compilation process (indeed, it is generated in a virtual session directly after compilation of the module). In this virtual session the module is called internally with --html-description which generates the parameters/flags list in HTML format, along with '<module>.html', HTML header and footer the final HTML manual page is created and stored in the target binaries directory. In a separate process, the MAN format is generated from the complete HTML files.
     21In order to make sure that manuals build without issues, it can be useful to validate the HTML before submitting, e.g. here:
     22[https://validator.w3.org/]
    2123
    2224=== Module Manual Pages ===
