Changes between Version 5 and Version 6 of TracImport
09/05/24 03:39:30 (5 months ago)
  • TracImport
    v5 v6
    1212
    1313[https://trac-hacks.org/wiki/ExportImportXlsPlugin ExportImportXlsPlugin]: a plugin that adds an admin panel for exporting and importing tickets via '''XLS file'''. Requires the python packages xlwt/rxld.
    14
    15 == Bugzilla
    16
    17 [https://trac-hacks.org/wiki/BugzillaIssueTrackingPlugin BugzillaIssueTrackingPlugin]: a plugin that integrates Bugzilla issue data into Trac keeping TracLinks. Ticket data can be imported from Bugzilla using the [trac:browser:branches/1.4-stable/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the `contrib/` directory of the Trac distribution.
    18
    19 {{{#!python
    20 $ bugzilla2trac.py
    21 bugzilla2trac - Imports a bug database from Bugzilla into Trac.
    23 Usage: bugzilla2trac.py [options]
    25 Available Options:
    26   --db <MySQL dbname>              - Bugzilla's database
    27   --tracenv /path/to/trac/env      - full path to Trac db environment
    28   -h | --host <MySQL hostname>     - Bugzilla's DNS host name
    29   -u | --user <MySQL username>     - effective Bugzilla's database user
    30   -p | --passwd <MySQL password>   - Bugzilla's user password
    31   -c | --clean                     - remove current Trac tickets before importing
    32   --help | help                    - this help info
    34 Additional configuration options can be defined directly in the script.
    35 }}}
    36
    37 Currently, the following data is imported from Bugzilla:
    38  * bugs
    39  * bug activity (field changes)
    40  * bug attachments
    41  * user names and passwords (put into an htpasswd file)
    42
    43 The script provides a number of features to ease the conversion, such as:
    44  * PRODUCT_KEYWORDS: Trac has no concept of products, so the script provides the ability to attach a ticket keyword instead.
    45  * IGNORE_COMMENTS: Don't import Bugzilla comments that match a certain regexp.
    46  * STATUS_KEYWORDS: Attach ticket keywords for the Bugzilla statuses not available in Trac. By default, the `VERIFIED` and `RELEASED` Bugzilla statuses are translated into Trac keywords.
    47
    48 For more details on the available options, see the configuration section at the top of the script.
    4914
    5015== Jira
    7136[https://trac-hacks.org/wiki/ScarabToTracScript ScarabToTracScript]: a script that migrates Scarab issues to Trac tickets. Requires [https://trac-hacks.org/wiki/XmlRpcPlugin XmlRpcPlugin].
    7237
    73 == Sourceforge
    74
    75 [https://trac-hacks.org/wiki/SfnToTracScript SfnToTracScript]: importer of !SourceForge's new backup file (originated from #Trac3521).
    76 Also, ticket data can be imported from Sourceforge using the [trac:browser:branches/1.4-stable/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution.
    7838== Other
    7939
    8040Since Trac uses a SQL database to store the data, you can also custom-import from other systems by examining the database tables. Just go into [https://www.sqlite.org/sqlite.html sqlite] command line to look at the tables and import them from your application.
    81
    82 === Comma delimited file - CSV
    83
    84 See [trac:attachment:csv2trac.2.py:wiki:TracSynchronize csv2trac.2.py] for details. This approach is particularly useful if you need to enter a large number of tickets by hand. Note that the ticket type type field, (task etc.) is also needed for this script to work with more recent Trac releases.
    85
    86 Comments on script: The script has an error on line 168: 'Ticket' needs to be 'ticket'. Also, the listed values for severity and priority are swapped.
    8741
    8842----
