Changes between Initial Version and Version 1 of TracPermissions
12/09/07 12:39:01 (17 years ago)
  • TracPermissions
     1= Trac Permissions =
     2[[TracGuideToc]]
     4Trac uses a simple permission system to control what users can and can't access.
     6Permission privileges are managed using the [wiki:TracAdmin trac-admin] tool.
     8Non-authenticated users accessing the system are assigned the name "anonymous". Assign permissions to the "anonymous" user to set privileges for anonymous/guest users. The parts of Trac that a user does not have the privileges for will not be displayed in the navigation.
     10In addition to these privileges, users can be granted additional individual rights in effect when authenticated and logged into the system. All logged in users belong to the virtual group "authenticated", which inherits permissions from "anonymous".
     12== Available Privileges ==
     13
     14To enable all privileges for a user, use the `TRAC_ADMIN` permission. Having `TRAC_ADMIN` is like being `root` on a *NIX system, it will allow you perform any operation.
     15
     16Otherwise, individual privileges can be assigned to users for the various different functional areas of Trac (note that the privilege names are case-sensitive):
     17
     18=== Repository Browser ===
     19
     20|| `BROWSER_VIEW` || View directory listings in the [wiki:TracBrowser repository browser] ||
     21|| `LOG_VIEW` || View revision logs of files and directories in the [wiki:TracBrowser repository browser] ||
     22|| `FILE_VIEW` || View files in the [wiki:TracBrowser repository browser] ||
     23|| `CHANGESET_VIEW` || View [wiki:TracChangeset repository check-ins] ||
     25=== Ticket System ===
     27|| `TICKET_VIEW` || View existing [wiki:TracTickets tickets] and perform [wiki:TracQuery ticket queries] ||
     28|| `TICKET_CREATE` || Create new [wiki:TracTickets tickets] ||
     29|| `TICKET_APPEND` || Add comments or attachments to [wiki:TracTickets tickets] ||
     30|| `TICKET_CHGPROP` || Modify [wiki:TracTickets ticket] properties (priority, assignment, keywords, etc.) except description field ||
     31|| `TICKET_MODIFY` || Includes both `TICKET_APPEND` and `TICKET_CHGPROP`, and in addition allows resolving [wiki:TracTickets tickets] ||
     32|| `TICKET_ADMIN` || All `TICKET_*` permissions, plus the deletion of ticket attachments and modification of the description field ||
     34=== Roadmap ===
     35
     36|| `MILESTONE_VIEW` || View a milestone ||
     37|| `MILESTONE_CREATE` || Create a new milestone ||
     38|| `MILESTONE_MODIFY` || Modify existing milestones ||
     39|| `MILESTONE_DELETE` || Delete milestones ||
     40|| `MILESTONE_ADMIN` || All `MILESTONE_*` permissions ||
     41|| `ROADMAP_VIEW` || View the [wiki:TracRoadmap roadmap] page ||
     42
     43=== Reports ===
     44
     45|| `REPORT_VIEW` || View [wiki:TracReports reports] ||
     46|| `REPORT_SQL_VIEW` || View the underlying SQL query of a [wiki:TracReports report] ||
     47|| `REPORT_CREATE` || Create new [wiki:TracReports reports] ||
     48|| `REPORT_MODIFY` || Modify existing [wiki:TracReports reports] ||
     49|| `REPORT_DELETE` || Delete [wiki:TracReports reports] ||
     50|| `REPORT_ADMIN` || All `REPORT_*` permissions ||
     51
     52=== Wiki System ===
     53
     54|| `WIKI_VIEW` || View existing [wiki:TracWiki wiki] pages ||
     55|| `WIKI_CREATE` || Create new [wiki:TracWiki wiki] pages ||
     56|| `WIKI_MODIFY` || Change [wiki:TracWiki wiki] pages ||
     57|| `WIKI_DELETE` || Delete [wiki:TracWiki wiki] pages and attachments ||
     58|| `WIKI_ADMIN` || All `WIKI_*` permissions, plus the management of ''readonly'' pages. ||
     59
     60=== Others ===
     61
     62|| `TIMELINE_VIEW` || View the [wiki:TracTimeline timeline] page ||
     63|| `SEARCH_VIEW` || View and execute [wiki:TracSearch search] queries ||
     64|| `CONFIG_VIEW` || Enables additional pages on ''About Trac'' that show the current configuration or the list of installed plugins ||
     65
     66== Granting Privileges ==
     67
     68You grant privileges to users using [wiki:TracAdmin trac-admin]. The current set of privileges can be listed with the following command:
     69{{{
     70  $ trac-admin /path/to/projenv permission list
     71}}}
     72
     73This command will allow the user ''bob'' to delete reports:
     74{{{
     75  $ trac-admin /path/to/projenv permission add bob REPORT_DELETE
     76}}}
     78The `permission add` command also accepts multiple privilege names:
     79{{{
     80  $ trac-admin /path/to/projenv permission add bob REPORT_DELETE WIKI_CREATE
     81}}}
     82
     83== Permission Groups ==
     84
     85Permissions can be grouped together to form roles such as ''developer'', ''admin'', etc.
     86{{{
     87  $ trac-admin /path/to/projenv permission add developer WIKI_ADMIN
     88  $ trac-admin /path/to/projenv permission add developer REPORT_ADMIN
     89  $ trac-admin /path/to/projenv permission add developer TICKET_MODIFY
     90  $ trac-admin /path/to/projenv permission add bob developer
     91  $ trac-admin /path/to/projenv permission add john developer
     92}}}
     93
     94Group membership can be checked by doing a {{{permission list}}} with no further arguments; the resulting output will include group memberships. Use lowercase for group names, as uppercase is reserved for permissions.
     95
     96== Removing Permissions ==
     97
     98Permissions can be removed using the 'remove' command. For example:
     100This command will prevent the user ''bob'' from deleting reports:
     101{{{
     102  $ trac-admin /path/to/projenv permission remove bob REPORT_DELETE
     103}}}
     104
     105Just like `permission add`, this command accepts multiple privilege names.
     106
     107You can also remove all privileges for a specific user:
     108{{{
     109  $ trac-admin /path/to/projenv permission remove bob *
     110}}}
     111
     112Or one privilege for all users:
     113{{{
     114  $ trac-admin /path/to/projenv permission remove * REPORT_ADMIN
     115}}}
     116
     117== Default Permissions ==
     118
     119Granting privileges to the special user ''anonymous'' can be used to control what an anonymous user can do before they have logged in.
     120
     121In the same way, privileges granted to the special user ''authenticated'' will apply to any authenticated (logged in) user.
     122
     123----
     124See also: TracAdmin, TracGuide and [http://trac.edgewall.org/wiki/FineGrainedPermissions FineGrainedPermissions]
