Changes between Version 23 and Version 24 of wxGUIDevelopment/ImprovingSingleWindowUX
- 03/05/23 10:22:13 (2 years ago)
v23 v24 45 45 {{{#!td 46 46 \\ 47 WIP 47 Ready to merge 48 48 \\ 49 49 }}} … … 54 54 }}} 55 55 {{{#!td 56 '''Undock and dock Map Display panel, Export history button in Console'''57 - https://github.com/OSGeo/grass/pull/2667 58 - https://github.com/OSGeo/grass/pull/2682 59 }}} 60 {{{#!td 61 \\ 62 WIP 63 64 DONE 56 '''Undock and dock Map Display notebook pane, Replace Log File button in Console pane by Export history button and change the logic accordingly''' 57 - https://github.com/OSGeo/grass/pull/2667: Adding a button for undocking an AuiNotebook tab to wx.Frame (Single-Window GUI) (linked to Issue: #1748) 58 - https://github.com/OSGeo/grass/pull/2682: wxGUI Console: Export history of executed commands 59 }}} 60 {{{#!td 61 \\ 62 Ready to merge 63 64 Merged 65 65 \\ 66 66 }}} … … 72 72 }}} 73 73 {{{#!td 74 '''Undock and dock Map Display panel, Export history button in Console'''74 '''Undock and dock Map Display notebook pane, Replace Log File button in Console pane by Export history button and change the logic accordingly''' 75 75 - https://github.com/OSGeo/grass/pull/2667 76 76 - https://github.com/OSGeo/grass/pull/2682 … … 78 78 {{{#!td 79 79 \\ 80 WIP 81 82 DONE 80 Ready to merge 81 82 Merged 83 83 \\ 84 84 }}} … … 90 90 }}} 91 91 {{{#!td 92 '''Undock and dock Map Display panel, Adding input string to command prompt'''93 - https://github.com/OSGeo/grass/pull/2667 94 - https://github.com/OSGeo/grass/pull/2718 95 96 }}} 97 {{{#!td 98 \\ 99 WIP 100 101 WIP 92 '''Undock and dock Map Display notebook pane, Adding input string to command prompt''' 93 - https://github.com/OSGeo/grass/pull/2667 94 - https://github.com/OSGeo/grass/pull/2718: wxGUI Console: Adding prompt string to command prompt (according to the idea in #2585) 95 96 }}} 97 {{{#!td 98 \\ 99 Ready to merge 100 101 Merged 102 102 \\ 103 103 }}} … … 109 109 }}} 110 110 {{{#!td 111 '''Undock and dock Map Display panel, Adding hint to command prompt''' 112 - https://github.com/OSGeo/grass/pull/2667 113 - https://github.com/OSGeo/grass/pull/2718 replaced by https://github.com/OSGeo/grass/pull/2728 114 }}} 115 {{{#!td 116 \\ 117 WIP 118 119 DONE 111 '''Undock and dock Map Display notebook pane, Adding hint to command prompt''' 112 - https://github.com/OSGeo/grass/pull/2667 113 - https://github.com/OSGeo/grass/pull/2718 114 - https://github.com/OSGeo/grass/pull/2718 replaced by https://github.com/OSGeo/grass/pull/2728: wxGUI Console: Adding hint to command prompt (showed as a more user-friendly variant which was even easier to implement) 115 }}} 116 {{{#!td 117 \\ 118 Ready to merge 119 120 Closed (abandoned) 121 122 Merged 120 123 \\ 121 124 }}} … … 127 130 }}} 128 131 {{{#!td 129 '''Undock and dock Map Display panel, Console reorganization'''130 - https://github.com/OSGeo/grass/pull/2667 131 - https://github.com/OSGeo/grass/pull/2746 132 '''Undock and dock Map Display notebook pane, Reorganization of Console buttons''' 133 - https://github.com/OSGeo/grass/pull/2667 134 - https://github.com/OSGeo/grass/pull/2746: wxGUI Console: Button reorganization 132 135 133 136 }}}
